Frickin' air bubbles
Well, I changed my coolant today. Got the crap scared out of me. Despite following all the posts and directions, when I was done I ruined my plans for the rest of the day.
After I was done I was driving all of about 3 miles when the car suddenly overheated. 5 bars in MY03.
Trouble is, I live on a 1700 ft hill. So I coasted down before it overheated. But it took me over an hour to get back up the hill cause I could only go a hundred yards or so back up the hill before I'd hit 4-5 bars again. Took forever to get home.
After I got home I did the bleading/purging procedure again about 4 times before I got all the air out and the heater was blowing hot air again.
Lesson learned: never try to shorcut stuff.
Originally Posted by s2000maniac,Nov 4 2010, 07:43 PM
okay...jacking the front and then how you bleed it?
- Jack up front of car
- Make sure radiator is full and overflow tank is at high level
- Re-cap radiator
- Crack open bleeder valve on intake manifold
- Squeeze upper radiator hose until liquid comes out of bleeder valve, then
immediately close bleeder valve (while maintaining pressure on rad hose)
- Top off radiator with fluid, cap and repeat until no air comes out
- Now do the same process, but use the rear bleeder (on the firewall)
Hope that helps
Scott-
