Front End Pop
Old Mar 6, 2011 | 06:39 PM
tehjazon's Avatar
Default Front End Pop
Hi all, I picked up an '03 w/ 44k miles on it back in October and it has been a blast. Anyway, about 3 months ago the front end(I believe it's coming from the right side) started to POP extremely loud when making a low speed sharp turn (e.g. when i'm parking)...but it only occurs when it's wet out. I don't believe it's ever happened when driving in dry weather, though I have started to notice squeaking lately, but I'm hoping that's just bushings needing lubrication.
Anyone have any ideas? I've babied the car since I've had it and have driven it like a little old lady. Of course, I have no idea how hard the previous owner beat on it.
I'm considering taking it to a decent alignment shop and having them look at the front end before I break down and take it to Honda. Hoping I won't have to!
Old Mar 7, 2011 | 01:45 AM
SgtB's Avatar
Could be a worn tie rid end, suspension pivot, balk joint, or steering rack mount. Almost anything. You could jack that corner up and shake everything. An alignment shop is a good option too if they're good.
Old Mar 7, 2011 | 04:30 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Check your mounts for the upper a-arms in the front of the car where they are welded to the body. The steel has been know to crack, and make a popping noise.
Old Mar 7, 2011 | 07:06 PM
tehjazon's Avatar
Thanks a bunch
Old Mar 10, 2011 | 01:39 PM
tehjazon's Avatar
Took it two different places today and no one could find a problem...looks like I'll be crawling under it if it ever stops raining
Old Mar 10, 2011 | 04:11 PM
Billman250's Avatar
Top Answer: 1
The cracks in the upper a-arm mounts will not be easy to see. Triple check them. trust me.
Old Mar 10, 2011 | 05:18 PM
starchland's Avatar
have you gone around under to check the bolt torques of the subframe etc
Old Mar 11, 2011 | 05:48 AM
JEEBS's Avatar
After reading this thread, I myself have experienced this exact same pop. Mine started after I installed my Whitline FSB. I am leaning towards my endlinks. I have a new set ordered. After install, I want to see if it will resolve the issue. Check your endlinks maybe?
_deleted
Jan 1, 2015 11:51 AM
ztrujillo
San Diego S2000 Owners
Mar 26, 2012 01:39 PM
dbaman007
Apr 25, 2006 10:22 AM
Cape Cod
Aug 21, 2003 06:40 AM
Vrm Vrm
Feb 18, 2002 04:48 PM
