Front park lights don't turn on
Old Jan 23, 2012 | 06:29 PM
bbss2k's Avatar
Default Front park lights don't turn on
I have a MY00 and the front park lights / running lights don't turn on when the headlight switch is turned to the first or second posission. All other lights work, i.e. all turn signals, headlights, hazards, rear running lights, brake lights, all interior lights (most of the interior lights share a fuse with the park lights, or so I've read). When I lock or unlock the car with the remote, the rear lights flash but the fronts don't. I found a thread about this from a year ago but no one had a real answer, just to check the fuses and wiring. All fuses are good and I would think that if it was a wiring problem then the lights wouldn't work when the turn signal is applied. Anyone have this problem or have a solution? Thanks
Old Jan 23, 2012 | 06:42 PM
importkid's Avatar
replace the bulbs. 194
Old Jan 23, 2012 | 06:54 PM
bbss2k's Avatar
If the bulbs were bad, wouldn't the turn signals not work?
Old Jan 23, 2012 | 06:55 PM
s2kftw's Avatar
^^^two separate bulbs... Replace the bulbs OP
Old Jan 23, 2012 | 07:03 PM
importkid's Avatar
Yes, the bulbs are separate. This also means that you will need to double check you are removing the parking lamp and not the blinker.
Old Jan 23, 2012 | 08:16 PM
Zoomie's Avatar
I have a front parking light bulb that goes in and out intermittently and nothing I can trouble shoot has figured it out... New bulbs, nothing I can figure out. Intermittent problem... Not to thread jack, but just throwing it out there that it may be more than just the bulbs.
Old Jan 23, 2012 | 08:58 PM
nartnailuj's Avatar
what kind of bulbs are they? any autozone or some sort would carry these?
Old Jan 23, 2012 | 10:12 PM
supavinn's Avatar
go to walmart. take out your old 1. and go find a matching one at walmart. i got mine for 2 bucks
Old Jan 24, 2012 | 01:48 PM
bbss2k's Avatar
Thanks. For some reason I thought the park light bulbs and turn signal bulbs were the same
Old Jan 24, 2012 | 07:43 PM
jonmizu's Avatar
Might be a fuse? Does your horn work? Do the brake lights work
Also what about your cruise control?
