Front support beam input?
Old May 4, 2006 | 08:33 AM
Rusler Firbrand's Avatar
Default Front support beam input?
Anyone know the best method or tool to use shave down the corner of the front support beam?
Ive heard using center punch and hammer to push the corners
in by thatjoshguy
xviper i think used an angle grinder
http://www.amazon.com/exec/obidos/tg...643961-0205654
QUOTE (r_duff @ Aug 11 2005, 06:08 PM)
shaving that upper corner of the bumper is a bitch!! I tried hammering, thinking it'd be much easier. Turns out, high-strength steel is stronger than my hammer... Thank god for dremmel
I currently only have a dremel, will this be sufficient enough?
Old May 4, 2006 | 08:37 AM
GranPrix's Avatar
dremel that sucker
Old May 4, 2006 | 09:34 AM
RadioZero's Avatar
angle grinder would be faster.
Old May 4, 2006 | 11:04 AM
iam7head's Avatar
this or 10 broken dremel disk
Old May 4, 2006 | 01:25 PM
xviper's Avatar
An angle grinder is the way to go. It's the "Tim the Toolman Taylor" way. A Dremel is a toy by comparison and would take way too long to grind off what you need to take off. Make sure you paint it after and let it dry a bit before putting the bumper on.
Old May 4, 2006 | 01:49 PM
clawhammer's Avatar
Just curious, Why?
Old May 4, 2006 | 02:01 PM
xviper's Avatar
On the right side in particular, you may have to grind off as much as an inch to an inch and a half of the corner. To do this with a Dremel would be absolutely painful. An angle grinder will do it in a matter of a minute or two. This is considered heavy duty grinding, not something that a wussy tool like a Dremel was really designed for. Of course, if that's all you have, then that's all you have.
OK, wait a minute. I just realized that you could be meaning something else. Like why do you have to grind it in the first place.
Converting an AP1 to an AP2 front bumper requires the corners to be ground down or the corners will poke the inside surface of the new bumper, causing a terrible dimple to occur.
Old May 5, 2006 | 06:15 AM
thanks viper, looks like i will have to shed out some money, im sure in the long run, i will find some use for this angle grinder.
Old May 5, 2006 | 06:20 AM
xviper are you talking 1 to 1-1/2 which way?
Old May 5, 2006 | 06:22 AM
Zeemz's Avatar
You might be able to rent one from a rental company.....
