Front windshield needs replaced
Old Feb 2, 2009 | 09:07 AM
zherbo's Avatar
Default Front windshield needs replaced
Front windshield needs replaced, on 2002 its pitted cheap factory glass. and from a couple of sesm events, local shop said $280 seems cheap,any one out there replaced theres, what kind of glass is better than oem?
Old Feb 2, 2009 | 09:16 AM
starchland's Avatar
only reason for replacement is pitting?
hmm if that was the case i would try to live with it. I dunno just from my experience replacing the oem glass is kinda a pain and can lead to problems.
Old Feb 2, 2009 | 09:33 AM
Ian300D's Avatar
Not sure what part of the country you live in, but down here you can get your windshield replaced so cheap because they get the glass from Mexico, and it sucks. Cracks very easily and from what I gather it is thinner. If it's just pitted then I would just ignore it, or replace it with OEM glass.
Old Feb 2, 2009 | 10:14 AM
tylorweaver's Avatar
I just paid $180 for mine installed from safelite..
Check them out. HIGHLY recommended.
GL
Old Feb 2, 2009 | 11:11 AM
jyeung528's Avatar
oem is probably the best glass, if not, then one of the best glass you can buy.
i would not recommend safelite.
at the very least go with PPG. PPG manufacturer's oem glass as well as aftermarket glass.
PPG OEM is probably the most expensive option.
something to keep in mind is that the windshield seal is strongest from the factory, and many installers do not do a good job with the seal, be it the quality or just the craftsmanship of their work.
i repaired a crack in my oem windshield to maintain the factory seal.
Old Feb 2, 2009 | 11:57 AM
zherbo's Avatar
Thanks maybe i leave it, i had one them done before and the problem was the final height issues, so water didnt drain at at bottom of windshield,any other moulding that one should replace at windshield replacement time
Old Feb 2, 2009 | 12:00 PM
Safelite worked great for me?? I'd say $170 installed is damn great, considering the quality of the glass, the install, plus the seal... No problems yet!
And at $170.. I'd say that's a disposable amount of money... So, it's not like you're dropping $500+ on a windshield, and getting a shit product, then having to have it replaced again in another year at $500+ again..
Just my $.02
Old Feb 2, 2009 | 01:15 PM
zherbo's Avatar
How was the black banding around the outside of windshield, thanks for the info
Old Feb 2, 2009 | 01:38 PM
cdelena's Avatar
GL
Great price... the lowest I can find OEM here is $278 and the lowest quote from Safelte is $310. I was ready to get it replaced after reading your post but the extra hundred is slowing me down.
Old Feb 2, 2009 | 07:06 PM
Perfect, almost flawless.. Looks like it was done at the factory!
