Fuel cleaner
Old Aug 22, 2007 | 03:39 PM
Saki GT's Avatar
Default Fuel cleaner
I want to use some Techron fuel cleaner in my gas tank, but I'm sitting on a full tank. Directions state to put it in before filling an empty tank, and I'm wondering if I can put it in now or do I have to wait for my tank to run dry again. I want to do an oil change asap, so its a matter of 300 mi or 600 mi to me - not a big deal.
Opinions?
Old Aug 22, 2007 | 03:43 PM
s98d7fs's Avatar
I believe the reason for adding the fuel system cleaner before a fill-up is just to aid in mixing the cleaner better. Really, adding it to a full tank will do just about the same thing. Sloshing fuel around in your tank should be enough to get the same mixing done .
Old Aug 22, 2007 | 03:53 PM
mikegarrison's Avatar
[QUOTE=Saki GT,Aug 22 2007, 04:39 PM] I want to use some Techron fuel cleaner in my gas tank, but I'm sitting on a full tank.
Old Aug 22, 2007 | 03:54 PM
Saki GT's Avatar
Pretty much. I know adding fuel after the cleaner will help break it up - I'm not sure if it stays concentrated if you dump it into a full tank and all gets sucked into the engine at once though.
Old Aug 22, 2007 | 03:57 PM
I figure Chevron tried it both ways and suggested using the way that worked best.
Old Aug 22, 2007 | 07:35 PM
CKit's Avatar
Wait until you burn a few gallons of gas, add the cleaner, then add gas on top to mix it up.
Old Aug 22, 2007 | 10:17 PM
RACER's Avatar
I'd burn about 1/2 a tank, then add the cleaner and top it off.
Old Aug 23, 2007 | 03:15 AM
iam7head's Avatar
i use it only when there;s quarter tank left, i run it until the last drop.
Old Aug 23, 2007 | 09:11 AM
NA20's Avatar
The reason for adding the Fuel Cleaner to an empty tank because over a very short time, the Fuel Cleaner evaporates... For it to be effective, you want it to enter the fuel system right away...
Old Aug 23, 2007 | 11:00 AM
MikeyCB's Avatar
I just did this 2 days ago but I had a half-full tank so I poured in the cleaner and put gas on top to full.
