Fuel feedline bolt
Old Mar 16, 2006 | 02:23 PM
GDM S2K's Avatar
Default Fuel feedline bolt
Ok baer with me.. I need to know the size of the fitting that connects the banjo bolt that goes to our rail to the fuel line by the compressor. Hopefully someone can help me out with this
Old Mar 16, 2006 | 03:09 PM
GDM S2K's Avatar
i dont need the metric size of the outside of the bolt I need the thread of the bolt
Old Mar 17, 2006 | 05:48 AM
CIVICTOS2000's Avatar
what are you trying to do?
Old Mar 17, 2006 | 06:09 AM
GDM S2K's Avatar
Run a larger line for a aftermarket fuel rail and regulator
Old Mar 17, 2006 | 06:39 AM
Wisconsin S2k's Avatar
Why? (just curious. i dont know the answer to your question)
Old Mar 17, 2006 | 06:57 AM
GDM S2K's Avatar
I got a aftermarket fuel rail and FPR and wanted to run a steel braided line from the hard line undernieth
Old Mar 17, 2006 | 07:16 AM
Oh ok. keep in mind even if you try to "turn up" your fuel, the ECU will compensate by cutting back injector pulse.
unless of course you have an aftermarket ECU.
free bump....
Old Mar 17, 2006 | 07:44 AM
GDM S2K's Avatar
free bump....
Well the car is going turbo its halfway disassem right now and im doing my fuel system while the car is down. Yes I have a AEM EMS too
Old Mar 17, 2006 | 08:15 AM
hondamanwill's Avatar
22mm
Old Mar 17, 2006 | 09:20 AM
GDM S2K's Avatar
Originally Posted by hondamanwill,Mar 17 2006, 09:15 AM
22mm
Would you happen to know what size fitting I can use or have made?
