Fuel filter
Old Nov 2, 2013 | 03:46 PM
AusS2000's Avatar
Default Fuel filter
I realised this has been discussed before but I've heard something new and wanted to clarify it with those in the know.
I always thought the one and only fuel filter was the sock on the end of the fuel pump (A). I got into a discussion with a guy who believes there is filtering material in plastic casing (B). Anyone know which is correct?
Old Nov 2, 2013 | 04:22 PM
XxMerlinxX's Avatar
I want to say that I remember reading that there's an actual filter attached to the pump itself, other than the sock, but that it's not really a regular service item.
Old Nov 2, 2013 | 04:30 PM
zeroptzero's Avatar
There is a fuel filter built into the upper housing, beyond the "sock" which is just a pre-filter against larger particles. In North America it isn't a well known detail as the parts are designed to last the life of the vehicle, and only changed if you develop low fuel pressure issues ( though I'd probably change mine if and when I replace my fuel pump, as I don't want to go in there more than one time).
For some reason in Australia I've heard that Honda dealers advise owners to change the fuel filter on a regular basis, which sounds like an expensive proposition to me. I want to say that the Australian fuel filter change interval sounds like a bit of overkill, but there may be an underlying issue with fuel quality in your country which we aren't familiar with?
Old Nov 2, 2013 | 05:14 PM
AusS2000's Avatar
Thanks for that guys. Seems I'm having humble pie for lunch.
Z32MadMan
Dec 3, 2016 09:48 AM
Creed5150
Jan 14, 2013 05:08 AM
TerminatioN
Jun 23, 2011 03:52 PM
dereks2000
May 17, 2003 06:37 PM
