Fuel filter change on AP2?
I've searched all over the site and haven't found the answer. Does our S2K's require a fuel filter change? I know on a lot of cars like the G35 its permanent. I'm assuming not finding anything with the words 'fuel filter' in any forum that the answer is no. Can someone confirm for me?
Haven't been on the site in over a couple years. Nice to be back!!
2008 S2K daily driver running strong as ever. 51K on it.
Thanks in advance.
Thanks in advance.
Nope... only has a fuel sock on pump, never change that I assume there's no need too. I know full blown makes a fitting for stock line if you would like to add a filter.
Sent from my SPH-L710 using Tapatalk 2
There is a fuel filter inside the large plastic piece that connects to the fuel pump and sending unit in tank, in addition to fuel pump sock. In this part of the world it isn't a regular maintenance item unless you have fuel pressure problems, it is designed for the life of the vehicle unless there is a fuel issue. I have seen some Australian owners state that they are regular replacement items over there.
