Fuel Injectors
Hey guys,
I have an 02' S2000 and already replaced spark plugs and coil packs and still getting misfire codes as well as random misfire code(s).
The car sputters at idle sometimes, has the typical rough idle but smooth/good power delivery after acceleration or revving.
I have read multiple threads about these symptoms and really want to replace the injectors to see if this is indeed the issue.
What size/flow are the stock injectors and where is the best place to get them?
Regards,
Jonathan
Regards,
Jonathan
send your stock injectors to RCengineering for a professional cleaning job. I sent my oem injectors to them and they came back 100% perfect. Before i sent them i had misfire codes on all cylinders, they were sitting for like 7 years.
it will cost less than $130.00 for all 4 to be cleaned vers $ brand new ones which will be much more expensive.
