FUEL LEAK. need some help
Old Oct 1, 2012 | 09:01 PM
chriss.'s Avatar
Default FUEL LEAK. need some help
Hey guys,
so iv had this fuel leak issue on my s2 for a while now.. and today i finally decided to see where the leak was coming and found that it was leaking from the fuel feed hose.. which is #3 in this diagram: http://www.hondapartssales.com/lisle...4s2a01_b04.png . the leak was coming from where the hose connects to the hardline on the top of connection.. and the hose did look loose sitting over the hardline, almost like there should have been a clamp holding it secure.. if that makes sense. there is no cracks at all in that tube, so what i did was zip tied it closed around where it connects to the top. and that seemed to do the trick. so was just wondering if what i did will work? or cause any problems in the future etc..
thanks.
Old Oct 1, 2012 | 09:08 PM
chriss.'s Avatar
here is a picture of the line and how i fixed it..
Old Oct 2, 2012 | 06:17 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That will not work. All you did was zip tie the foam cover.
That is a high pressure line and I would strongly reccommend replacing it. If that fuel finds its way to an ignition source (like the alternator, its right there) it will be serious and dangerous.
A low pressure line you could doctor up, but not this one.
Old Oct 2, 2012 | 05:46 PM
chriss.'s Avatar
Im going to replace the line in the spring, but for now i need a temporary fix.. so i removed that zip tie and put a hose clamp instead.. there is no leaks at all now with that clamp. hoping it should be fine till spring ?
Old Oct 2, 2012 | 05:56 PM
jst2878's Avatar
Good luck
Old Oct 2, 2012 | 06:26 PM
miguel329's Avatar
Sounds like yours will be next...
Sent from my PC36100 using Tapatalk 2
Old Oct 2, 2012 | 06:38 PM
ed-gsxr's Avatar
If I were you I would definitely replace it asap if ur S is daily driver. Its not worth risking the potential of a fire.
Old Oct 2, 2012 | 08:22 PM
chriss.'s Avatar
Okay I will replace the line ASAP... will prob do it myself though, so is there any DIY on how to do this? Or someone can give me some ideas. Also when attempting this do I need to remove fuel pump fuse at all or anything?
Old Oct 3, 2012 | 11:27 AM
zeroptzero's Avatar
To replace that part you have to loosen the fuel dampener (UFO looking thingy on top), that will release fuel pressure, but you will still get a good bit of fuel leakage just not under too much pressure. Then you have to replace two crush washers for installation, you might as well order them now as they are always on back-order it seems and may take a while to get. You can run the car and pull the fuel pump fuse as well to reduce fuel pressure and seepage as well.
Old Oct 3, 2012 | 05:08 PM
chriss.'s Avatar
So i got the fuel line out, and that fuel feed hose is on back order for a month from honda so i have a steel braided line i was thinking of using instead.. so was wondering if anyone knows sizes of the fittings i will need to bolt on fuel rail and fuel pipe.
Also JFUSION.. what crush washers are you talking about? there was none on the factory line from what i could see..
