Fuel system
Old Mar 29, 2017 | 03:56 PM
BlakeJS2K's Avatar
Default Fuel system
I just purchased a walbro fuel pump,aem fuel regulator, id1000 fuel injectors, and an aem infinity. I've been searching for a few hours and can't find a good clear explanation on how install the products. Some things are straight forward but the injectors have me a little confused and so does the fuel regulator. Any help is appreciated, thanks.
Old Mar 29, 2017 | 05:03 PM
BlakeJS2K's Avatar
I am having the hardest time getting the fuel dampener off. Any ideas?
Old Mar 29, 2017 | 10:06 PM
flanders's Avatar
22mm wrench and a mild tap with a hammer should break it loose.
Are you sure you need to remove the dampener though?
Old Mar 30, 2017 | 02:31 AM
BlakeJS2K's Avatar
After looking more I decided not to take it off. Is the another way I can remove the fuel rail tho? Would make things much easier.
Old Mar 30, 2017 | 08:19 AM
flanders's Avatar
If you are just changing injectors you shouldn't need to take it off completely, just loosen the mounts to the manifold.
You can remove the rail completely without loosening the dampener if you disconnect the connection to the hard line, but this is probably harder and I wouldn't recommend it.
Old Mar 30, 2017 | 08:39 AM
BlakeJS2K's Avatar
alright, I'll leave it be. I think I can get the injectors in. But do you know of any aem fuel regulator install tutorial? Cause I'm super confused.
Old Mar 30, 2017 | 09:11 AM
flanders's Avatar
I'm sure there are several on this forum https://www.google.se/webhp?sourceid...ite:s2ki.com&*
Old Mar 30, 2017 | 12:02 PM
BlakeJS2K's Avatar
nothing seems to be up to date or has a different regulator. I included a picture because I have no idea what the three holes around the sides are for.
Old Mar 31, 2017 | 02:21 AM
flanders's Avatar
Looks like you got the universal model, that wont work with the stock fuel rail.
Do you need to change the stock one though?
ID1000 should provide plenty of fuel on stock fuel pressure.
Old Mar 31, 2017 | 06:05 AM
BlakeJS2K's Avatar
that kinda pisses me off. I went through realstreet and the guys set everything up for me. I asked him give me everything I'll need to be able to run e85 and prepare for turbo set up. Does that make a difference?
