garbage or salvagable? Head Picture
Old Jun 30, 2006 | 06:22 AM
Scot's Avatar
Default garbage or salvagable? Head Picture
any value to this thing?
thanks
Old Jun 30, 2006 | 08:01 AM
SCCS2K's Avatar
Ouch!! Sorry to see that. Not sure about value, though.
Old Jun 30, 2006 | 08:20 AM
vtec9's Avatar
looks kinda nasty.. you could probably sell it to some poor fella on ebay
Old Jun 30, 2006 | 08:24 AM
NFRS2kSi's Avatar
ouch.. can't c.. well, but is that a broken valve or bent?... ... my eyes r getting old... if the valve port(the hole) is in good, i think it's still good... but if the port gone bad...... i wouldn't consider fixing it.
Old Jun 30, 2006 | 08:55 AM
iDomN8U's Avatar
The port is munched... those gouges can't be machined.
Good look on finding a new head.
Have you checked the Cylinder wall to see if the metal bits didn't do the same there?
If it has and it's deep enough, I'm not sure if the block is reusable. Perhaps you can do some work to increase the bore and use larger pistons.
Old Jun 30, 2006 | 09:23 AM
ScottyBallistic's Avatar
You would have to have a new valve seat installed along with a new guide and valve . It is do able .
You would have to have a shop inspect it for tolerance as we can not see .001 of a inch in a picture .
Nicks can be repaired in the chamber with some TIG skills .
That assuming that you have no damage to the cam towers or rocker assembly . As you can not buy the towers separately
You have a PM
Old Jun 30, 2006 | 10:02 AM
Scot's Avatar
okay....it is going into the recycle pile..... didn't want to toss it to find out it had value....
ebay "needs minor work"....
Old Jun 30, 2006 | 10:14 AM
iDomN8U's Avatar
May I ask what happened for it to do that?
Old Jun 30, 2006 | 10:41 AM
Scot's Avatar
broke a valve and beat the shit out of the piston........ that happens when you downshift from 5th to 2nd...
Old Jun 30, 2006 | 11:21 AM
vtec9's Avatar
"fresh valve job"
