Gas cap loose
Old Jul 20, 2006 | 10:36 PM
Spec_Ops2087's Avatar
Default Gas cap loose
Well driving home from work today and the darn check engine light goes off. I don't think much of it because I wasn't driving hard and the car didn't feel any different. Just the other week my gas cap was loose so I figured I would check it. Sure enough it was loose AGAIN.
The problem is, I make sure the gas cap is always fully closed with at least "3 clicks," usually more. The first gas cap that came with this car kept on coming loose and they replaced it under warranty. Now this semi new one is doing the same thing (I guess its about a year old or so). I'm starting to think maybe the threads on the tank are bad?
Is there anything I can do aside get ANOTHER gas cap?
Thanks
Old Jul 20, 2006 | 10:45 PM
NFRS2kSi's Avatar
i think there was a re-call regarding gap getting loose?... was it 350Z? i dunno... ... maybe xviper would know more about this.
Old Jul 21, 2006 | 05:04 AM
MikeyCB's Avatar
Related to the Fuel Filler Neck Deformation TSB I believe
I have problems with my MY02 as well. When I tighten the cap it will get to a point where it clicks continuously, but isn't actually tight. I find if you tighten your cap by holding it around the outside rim of the cap (like opening a bottle of beer) instead of using the flat bar/handle on the centre of the cap, that it tightens much better and makes it past that point for another couple rotations and a full tight seal
Old Jul 21, 2006 | 05:14 AM
slalom44's Avatar
Top Answer: 1
I had the same problem. The Fuel Filler Tube is defective and needs to be replaced. Go to your dealer and tell them to look up TSB 04-002. This isn't a recall, but a technical service bulletin. I had mine replaced under warranty.
hawkman199
May 23, 2012 05:03 PM
EsTooTouseng
South Florida
Oct 20, 2010 02:02 PM
Ubetit
Feb 9, 2008 11:56 AM
REVS 9K
Aug 11, 2005 11:38 AM
Strike
Oct 10, 2003 05:50 AM
