Gear Change Issue Solved--> Check out the Clutch
Old Jun 4, 2010 | 09:30 AM
Jspd's Avatar
Default Gear Change Issue Solved--> Check out the Clutch
So last night all is fine with the S and so I stop by a buddies house. I stay for a couple hours and then leave. A few miles later the car just stops going into most of the gears,..particularly on down shifts. I flushed the trans fluid and adjusted the clutch along with a clutch master cylinder flush. Now the car seems to go in to gear on up shifts fine (keep in mind I have not done any high rpm shifts) but down shifting to 3rd and 2nd are still very difficult and it does grind a bit. I have noticed that after hard driving the clutch was not sticking as well so I dont know if that is the issue or not. I need some guidance as this is my daily driver right now.
As a side note the car is a MY02 (93K on the odometer) and I do track the car and am very aggressive on the street. I do my own up keep/repairs and meticulously perform all routine maintenance on it. I did however let the trans fluid go for 30K which was unfortunate as I usually do it every third oil change.
Thanks in advance for your help. I am about to pull the trigger and buy a trans and clutch and swap it out just to get this car taken care of.
Update 6/18--> So here is the picture of my clutch after I took it out. I have never seen this happen before. Anyone else see this before??
Old Jun 4, 2010 | 11:29 AM
rob-2's Avatar
billman might have some comments on this. He mentioned in another thread a sticky shaft - might be the source of your problems. And/or your clutch may just be on the way out.
Old Jun 4, 2010 | 03:12 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It's your clutch man
You either have a broken disc, or rusty spline.
Old Jun 4, 2010 | 03:53 PM
Jspd's Avatar
Thanks for the feedback Billman!! I did do some high rpm up shifts and it grinds going into the gears and is still hit and miss on the downshifts. Does this still sound like the clutch?! I just want to double check before I click 'confirm' and drop the cash. Thanks again for all the help!
Old Jun 18, 2010 | 09:05 AM
Jspd's Avatar
Updates ^^^
Old Jun 20, 2010 | 01:16 AM
Seattle2k's Avatar
I just did a clutch job and don't recall any discoloration like yours is showing. Looks like it got really hot at some point.
Old Jun 20, 2010 | 06:07 AM
whites2k03's Avatar
it might have warped when it got hot (the discoloration of metal) when it warped it easily could catch and rip like that on something.
My stock clutch was almost smooth at 104k when I took it out but there was no discoloration of the clutch at all.
Old Jun 20, 2010 | 07:52 PM
Suzuka_Joe's Avatar
no discoloration on my oem clutch when i pulled it last week. 74k and 2k of it was turbo
Old Jun 21, 2010 | 10:08 AM
wadzii's Avatar
Banned
mine was almost torn out like this when i pulled my clutch, EVERY sprung disk i have ever had in any of my previous cars did that.
From what i can tell if you downshift at high rpm's it will make that problem worse.
its fun when those come all the way out, the pieces usually find their way into the pressure plate making it so that you cant disengage the clutch
Old Jun 21, 2010 | 09:22 PM
Kmelthratter's Avatar
My old integra was starting to do that to the OEM clutch. 100k miles and 13 passes, plus being 16 kinda did it in.
