Gearbox whine
Old Feb 5, 2008 | 10:55 AM
Xd's Avatar
Xd
Default Gearbox whine
I know there is a thread concerning this, I'd like to see about fixing this myself.
There is a rubbing sound comming from the rear of the gearbox. Its has been like this for some time and the car is running fine. I know this is caused by some damaged bearings on the shaft and there was a thread about this some time ago. Can someone point me in the direction for that thread please.
Old Feb 5, 2008 | 04:21 PM
negcamber's Avatar
Have you listened to other s2ks? Most of them have very loud gearbox whine even at idle and in neutral.
Old Feb 5, 2008 | 04:25 PM
S2KBLanton's Avatar
Why is that? I have noticed it on mine as well
Old Feb 5, 2008 | 05:27 PM
ATOice's Avatar
Mine whines also.
Old Feb 5, 2008 | 07:04 PM
RedY2KS2k's Avatar
How did your previous tiff with Honda turn out?
Old Feb 5, 2008 | 07:35 PM
PWRMKR's Avatar
Sure.
Read this thread > Gear box / transmission whining noise.., ****SOLVED WITH PICS!****
Old Feb 5, 2008 | 10:17 PM
Xd's Avatar
Xd
No this isn't the when idle whine, you only get this when moving. It has been on the axle stand and was diagnosed as a problem with the rear roller bearings. Honda's solution was a new gearbox which they offered to pay I think 70% of the cost of. That would come to
Old Feb 6, 2008 | 08:51 AM
jettfiery's Avatar
mine has the same exact problem. Although not recommended, it is possible to replace the bearings without removing the transmission. I believe that the thread above mentions it. Again, it's not the 'proper' way of doing things since there will be shavings throughout the entire gearbox. I would take out the entire tranny to fix it if i had the right tools, time, and needed to replace my clutch but o well.
Old Feb 6, 2008 | 09:20 AM
Xd's Avatar
Xd
I know but I kinda cherish this car, everything has to be right else I get annoyed. I think a possible cause of the original problem was using Redline in the box. Especially as these bits are at the oil starved end.
Well I've found a replacement gearbox, similar milage for
