Going back to stock clutch, quick question
Old Feb 11, 2009 | 06:14 PM
dtmcnamara's Avatar
Default Going back to stock clutch, quick question
Ok so I just swapped my tranny from a 2001 to a 2005. Love it, feels great, and everything, but I did it in order to fix my clutch rattle.....WTF was a thinking...DUHHH!!!
Clutch rattle...a tranny swap will not change this. I swapped the tranny and left the Comp. Clutch setup on the car. 3 days later the buzz is starting to get louder and louder.
I am going with the ACT pressure plate and disk (so pretty much OEM), my question is I have a light weight flywheel. I have learned to drive with it, but does this contribute to any access noise? I will swap it back to my OEM flywheel if I need to, but if it does not contribute to anything I will just resurface it, if needed, and leave it in.
Told you it was quick...thanks
Old Feb 11, 2009 | 06:53 PM
negcamber's Avatar
It better not be...it should be a fairly solid hunk of metal. The buzz is usually caused by the friction disk springs.
Old Feb 11, 2009 | 06:59 PM
TJ01s's Avatar
what? I thought the clutch buzz was caused by the tranney creating harmonics that rattle the springs within the disc! my01 rattles so bad in decel that it also makes this god-awful noise from the trunk area!!
sorry for not helping, but the most difinitive explanitaion i have been able to find was the tranny caused the buzz, regardless of what clutch you have, at least with the early modles.
Old Feb 11, 2009 | 07:00 PM
dtmcnamara's Avatar
ok thats what I was thinking....
one other question. I have the Competition Clutch stage 2 setup. If I were to just buy a new disk, say a OEM one, would I still have a buzz? Or would it just be better to get the ACT PP and disk?
Old Feb 11, 2009 | 07:19 PM
RedY2KS2k's Avatar
No, that's not right.
I replaced just the clutch disk in my '00 a couple of years ago. Same transmission, but the car doesn't rattle and buzz like an expletive-deleted Yugo now. Of course, if the original disks had made the car sound like a poorly-built piece of crap when new, no one would have bought one. I just hope that as I get more miles on the new clutch disk, it doesn't start to sound like crap. If the noise comes back, I'll just sell the POS and move on. Piss poor build quality is piss poor build quality; I don't want to put up with it again.
Old Feb 11, 2009 | 10:03 PM
cdelena's Avatar
Use the OEM FD not the ACT.
Old Feb 12, 2009 | 01:46 AM
TJ01s's Avatar
true... I had the buzz when I got the car, wasn't too bad tho....just the standard whatever. after it wore out, i put in a 6-puck with lightened fly and HD PP. problem solved, for about 300 miles. now it sounds like there is something seriously loose in the back, like the $200 POS with 100,000 watts of bass rattling the trunk ,and i can't find it!!
back to the orig. question, i think you will be fine with just putting an oem disc back in, at least thats what is in the TSB's. i've read that they have changed the springs somehow and the buzz is lessened. IDK, i just push in the clutch at 3k rpm....no more buzz
Old Feb 12, 2009 | 04:05 AM
dtmcnamara's Avatar
ok so ACT PP and OEM disk
InTheZone
May 8, 2016 08:38 PM
Krisbuc
Dec 20, 2013 04:02 PM
MrChoi
May 7, 2009 01:18 AM
CKit
Aug 6, 2008 12:25 PM
c2d2
May 29, 2007 04:39 PM
