Going to replace tranny/diff fluid this weekend..
Old Sep 25, 2018 | 11:01 PM
calvinnnnn's Avatar
Default Going to replace tranny/diff fluid this weekend..
Is this the LE1605 that I need for the differential? And I'm guessing i'll need just slightly more than 1 bottle to fill it up? I used Amsoil the last time.
ALso, what do you guys use for the tranny? I used the Friction Modified Synchromesh from GM last time. ANy better fluids out there for the tranny?
Thanks!
Old Sep 26, 2018 | 01:38 AM
RolanTHUNDER's Avatar
I've never personally used LE before so I can't comment there but if it's GL5 for hypoid gears and 75W-90/110/140 then its fine for your diff. GL4 for the tranny. You could also consider Honda MTFIII from the dealer for your tranny.
Old Sep 26, 2018 | 04:52 AM
freq's Avatar
Yes, another fluid thread.
Old Sep 26, 2018 | 05:11 AM
Chuck S's Avatar
Been sleeping the past couple weeks and couldn't drop by here?
LE-1605 is NOT a GL-5 lubricant. Not anymore. Old formulation was GL-5 but it's not the same. Changed this year I think.
Anyway there's an extensive, fairly contentious, argumentative thread running with all the information I won't repeat since we don't need 3 or 4 threads on LE-1605. Grab a coffee or beer and start reading. Bottom line remains the same. LE-1605 is not a GL-5 lubricant.
-- Chuck
Old Sep 26, 2018 | 09:24 AM
Slowcrash_101's Avatar
Honda came out with MTF3?
Old Sep 26, 2018 | 10:43 AM
flanders's Avatar
It's probably been out for a decade by now
Old Sep 26, 2018 | 04:44 PM
darcyw's Avatar
rear diff takes about 800 ml, less than a quart (946 ml).
honda MTF for the trans.
darcy
Old Sep 26, 2018 | 05:11 PM
starchland's Avatar
OP, what is your address? I will send you a cookie.
Old Sep 26, 2018 | 10:03 PM
Looong ago
Old Sep 28, 2018 | 10:11 AM
calvinnnnn's Avatar
-- Chuck
Thanks Chuck. I was wondering whether they modified it or not as I recall reading about people using it several years ago.
