got the AEM V2... installation question?
Old Jan 30, 2004 | 08:38 AM
mav's Avatar
mav
OK I got the AEM V2 from Tim's GB - great price BTW - now I have an installation question. To install it I will have to remove the bottom bumper bolts and remove the passenger underside splash panel.
Because I have the Amuse front lip covering the three most center holes and its taped on, can I just loosen only the three most outer passenger side bottom bumper bolts in order to remove the passenger underside splash panel? Or will I have to completely loosen them all, which would mean I will have to also remove and reinstall my Amuse Front Lip?
Thanks.
Old Jan 30, 2004 | 09:23 AM
sebrings2k's Avatar
You can cut the inner fender trim without removing your bumper & tire.
Getting the filter in would be the hardest part, but I have been able to squeeze it in by removing some plastic clips and pulling the splash panel and inner fender trim apart.
You shouldn't have to remove any bolts at all.
Old Jan 30, 2004 | 09:50 AM
Fyrestrike's Avatar
You shouldn't have any problems installing it considering you had the V1 until now. The holes should be there, just make them larger.
Old Jan 30, 2004 | 09:52 AM
Chiung's Avatar
[QUOTE]Originally posted by mav
Old Jan 30, 2004 | 12:44 PM
Hunter's Avatar
Just did it, I agree with the above posts. Loosen and remove the wheel well and you'll be fine. Also, make sure solenoid hose are correct too. The instruction are foggy on that. Should be the same as your V1
Old Jan 30, 2004 | 01:03 PM
mav's Avatar
mav
Thanks for your replies, should be easy to install, I was only worried about the removal of the wheel well/undertray since my Amuse Lip is there.
Old Jan 31, 2004 | 06:48 AM
tims2k's Avatar
^ Mav...I have never done the install as Chiung and s2kjones did their own install outside of my shop
Fyrestrike- most of the owners who upgraded had the V1 and said it was pretty easy and the install was about the same except it needed bigger holes cut
tangelina
Aug 23, 2006 02:55 AM
jert534
Jul 16, 2006 01:20 PM
Jsy622
Mar 24, 2006 01:07 PM
bobatimez
Aug 18, 2004 01:52 AM
