Grey smoke!
Old Jul 21, 2010 | 04:29 PM
robertjr314's Avatar
Default Grey smoke!
I have noticed that after driving the car when I turn it off, then turn it back on within about 5 minutes.. I will start to get a cloud of grey smoke exiting my exhaust, it smells very much like burnt gas.. It started to happen after I installed my high flow cat( I think).. It also occured while resting at a gas station after three hours of driving.. My car was on the dyno and read 11.49 on the afr. I'm turbo, for only 4k miles.. Some friends tell me it could be blow by gas..
What do you think guys???
Old Jul 22, 2010 | 12:26 PM
Anyone???
Old Jul 22, 2010 | 12:40 PM
secondhandloser's Avatar
like a brief smoking, or a constant smoking?
Old Jul 22, 2010 | 12:46 PM
It's a brief smoke for about a minute.. It becomes a huge cloud of smoke.. But, after it settles and I get no more smoke..
Old Jul 22, 2010 | 12:52 PM
if a turbo is smoking at certain times, it's often going to be a drain issue. Check for: PCV venting properly, oil drain kinks, etc. check for shaft play in the turbo. It could be a bad turbo seal.
After you check those things, maybe compression check...
Old Jul 22, 2010 | 12:55 PM
My turbo is a greddy turbo and has only 4k miles..Do u think a catch can would help?? And should I do the compression Check???
Le S2K
Sep 4, 2015 08:03 AM
Jeremy Clarkson
Jun 1, 2013 09:35 PM
rikhemi
Mar 11, 2011 04:26 AM
NFRs2000NYC
Jan 26, 2009 07:44 AM
hondaBeater
May 5, 2008 04:13 PM
