Grinding on Cold Start
Old Jun 27, 2012 | 01:11 PM
jordaninabox's Avatar
Default Grinding on Cold Start
Whenever I start up my car for the first time in the morning for about a second I hear some horrible grinding noise from the start I am guessing. Can anyone confirm this? I would like to get it taken care of asap. It only does it that one time that I start it up in the morning and is done for the rest of the night.
Old Jun 27, 2012 | 07:26 PM
CoolGuy094's Avatar
Don't worry about it; it might just be the most common issue on all S2000's. You can do a quick search for "starter grind" in this forum and find hundreds of people with the same issue. It is the starter remaining in contact with the flywheel after the car cranks and it spins the starter quickly for a half second. Not detrimental to your car; I would learn to live with it (as we all have).
If you really want to fix it, replace your starter. I tried lubing the shaft that the starter gear glides on with no success. Starter replacement seems to be the only guaranteed way to stop this, but it won't last fovever. It will likely return on your new starter.
Old Jun 27, 2012 | 09:51 PM
davidc1's Avatar
What he said...
Old Jun 29, 2012 | 10:36 AM
Thank you very much, yes I have lived with it for about 8 months now and just wanted to make sure it was not causing any damage.
You guys rock
Old Jun 29, 2012 | 10:49 AM
unclefester's Avatar
Actually you don't have to live with it - you can 'service' the starter motor or swap it out for a reconditioned one. I took mine completely to bits, degreased and cleaned all the parts then regreased it and reassembled it - not had an issue since doing that. It's impossible to get grease into the correct part of the starter assembly without dismantling it.
https://www.s2ki.com/...1#entry21677168
Old Jun 29, 2012 | 01:39 PM
sillyboybmxer's Avatar
mine has been doing it for years.
very common.
solution,...get a supercharger. you wont hear it over the whistle
Old Jun 29, 2012 | 04:28 PM
Moddiction's Avatar
Former Sponsor
Mine does the same thing for years now! Annoying but doesn't bother me much anymore. I have a supercharger and still hear it loud and clear on start ups lol
00blackap1
Feb 15, 2012 04:45 AM
speedytweety
Apr 5, 2009 04:15 PM
quickshifting
Dec 5, 2007 01:15 PM
FirstBatRgr
Sep 20, 2007 09:19 PM
AZDavid
Oct 12, 2004 06:44 AM
