Grinding on start?
Old Jan 7, 2019 | 03:29 AM
igorien2k's Avatar
Default Grinding on start?
i had this happen a few times on cold mornings. Initially thought it was just the starter, but I wanted to know if there is a way to rule out more dangerous faults, such as a loose flywheel. Any thoughts?
The car has a lightened flywheel and an exedy oem replacement clutch.
Old Jan 7, 2019 | 04:11 AM
BootsS2K's Avatar
Video unavailable.
Old Jan 7, 2019 | 04:54 AM
The King's Avatar
I couldn't play your video, but I had a terrible noise from my car on start up a few months ago. I had the car on a battery tender for a while but the tender seemed to be working strangely. It kept alternating back and forth from showing fully charged to charging again. This went on for some time, so I tried my other tender. The battery appeared fully charged, so I removed it and attempted to start the car. It sounded terrible! I thought something major was wrong with the engine. I still had doubts that the battery had taken a full charge, so I picked up another battery and replaced the one in the car. The car started right up and the concerning racket was gone. I think the battery was so dead that the starter was not fully engaging the flywheel (I'm no mechanic). I also have an aftermarket clutch and lightened flywheel, but I doubt this had anything to do with my issue.
Old Jan 7, 2019 | 01:29 PM
Car Analogy's Avatar
Every year when weather turns cold a bunch of threads pop up about starter squeal. Its normal for our warm blooded cars. Nothing to worry about, just annoying and embarrassing.
Not usually perceived as a starter 'grind', so can't be sure this issue is our normal cold weather starter squeal. But that would be the first thing to rule out.
Old Jan 7, 2019 | 01:33 PM
BootsS2K's Avatar
My Element has a ''grind' for a few seconds when I cold start it in the winter. If the video worked, I'd tell you if it sounded the same.
Old Jan 7, 2019 | 07:04 PM
Zer0ne's Avatar
If it's a grind for a second after the car fires up, it's the starter. It keeps spinning for a second sometimes even after releasing the engine start button for some reason.
Old Jan 7, 2019 | 09:16 PM
soulicious's Avatar
The only time my s2k grinded was after damaging something from hitting the start buttton when the car was already running. That was 10 years ago and I haven’t had a problem since replacing the starter then.
Old Jan 11, 2019 | 02:12 PM
igorien2k's Avatar
Oh man! Clearly I do not know how to use the internet well. I had the video set to private. Is anyone able to view it now? BTW thanks for the replies so far!!
Old Jan 11, 2019 | 02:38 PM
BootsS2K's Avatar
I'm no expert but I'd guess starter
Old Jan 11, 2019 | 04:08 PM
Zer0ne's Avatar
Definitely the starter staying engaged. It happens with mine too, both with my original one and a used OEM replacement one.
Another thread discussing it
