Had a compression test and a leak down test...weird result?
Could be bad valves or guides which doesn't show up in compression test. You can have bad leakdown results with good compression. Usually an experienced mechanic will use the leakdown results to point you in the right direction of the bad parts.
BTW I just got home from being in Windsor, usually there every 2 weeks.
Thanks for the reply!
mrkim019
Nov 28, 2005 10:02 AM
