Hard throttle problem
Old Nov 11, 2014 | 01:32 PM
AP1Patrick's Avatar
Default Hard throttle problem
Okay so I've gone to 2 different shops and they couldn't tell me anything. I have a 2000 s2k and under normal conditions the car drives fine, but when I hammer the throttle I get major hesitation/misfire. In 1st gear the car dies completely pretty much until I get off the throttle. All the other gears I have bad hesitation and it's all around 5k rpm. I cleaned my throttle body, did the "MAP Whack" I replaced the plugs and I just can't pin down the problem. At idle it stays steady at 1k and every now and then u can hear it misfire a tad. If anyone has had a similar thing happen please let me know. I think it may be a coil pack but like I said at idle it doesn't feel like a bad coil, it's only when I'm under full throttle
Old Nov 11, 2014 | 01:50 PM
HUNTERANGEL121's Avatar
Check coils, and injectors?
I think there are a few threads on this...
Old Nov 11, 2014 | 04:05 PM
AP1Patrick's Avatar
The posts I've seen didn't entirely match my situation. Normal daily driving my car is fine and my idle is fine as well. Sorry if I posted an old topic tho
Old Nov 11, 2014 | 05:43 PM
I'm almost wanting to say its either your injectors(someone comment on this please)
Or coils.
Sent from my Nexus 5 using Tapatalk
Old Nov 12, 2014 | 07:39 AM
Slowcrash_101's Avatar
Check the vtec spring switch, it can bind. To do this remove the top part of the solenoid and push down on the spring.
stwokay
Mar 10, 2006 04:27 PM
NorthCyprus
Oct 5, 2005 09:27 AM
WalkingDrunken
Nov 23, 2004 10:35 PM
