Header
Old Aug 8, 2007 | 07:43 AM
HNC's Avatar
HNC
Default Header
Approximately how much would it cost to professionally install a set of headers into a 2002 S2000?
THanks
Old Aug 8, 2007 | 08:11 AM
SIIK2NR's Avatar
<$200
Do it yourself...it's not that difficult to do. In fact....it's pretty easy if you have tools.
Old Aug 8, 2007 | 09:04 AM
negcamber's Avatar
There is only one header on the s2k...so right there you saved money!
That is unless you really want a set installed...then you will have to pay out the ass while the mechanic figures out how to attach the 2nd header someplace so that it looks like it's doing something.
Old Aug 8, 2007 | 09:59 AM
Money2536's Avatar
Some header installs are a bit more difficult. My old Spoon header wouldn't fit, so I had to detach the motor mount, jack motor slightly, then put the header in place. It still wasn't overly difficult, but not as easy as a Mugen.
Old Aug 8, 2007 | 10:33 AM
MikeyCB's Avatar
It was a bitch getting mine in but the mechanic did it. I wouldn't attempt without a lift personally because you can't get the right viewpoints lying on your back.
Cost less than $100 for my mech to install.
Old Aug 8, 2007 | 12:34 PM
synergytone's Avatar
It's definitely something you can do on your own - the only big issue is getting the damn thing to fit in there - not much room to work with
Old Aug 8, 2007 | 01:17 PM
ATOice's Avatar
Less than 100 for a header.
negchamber
Old Aug 8, 2007 | 04:21 PM
madkimchi's Avatar
farily easy job as long as all the nuts and bolts loosen up easily.
Old Aug 8, 2007 | 08:09 PM
LemurFaktore's Avatar
easiest way, man up n do it yourself, save some cash and learn somethin new at the same time....then u could charge other people
Old Aug 10, 2007 | 08:32 PM
P5744D's Avatar
piece of cake only hard bolt is the one for the heat shield
