Header heat shield
Wow! You guys got me worrying now. I got a Spoon header, don't know if it's a "thin walled" like you guys mention. I've had it for about 10thousand miles, but it's not a daily diver now. It will be in Oct. when I retire. I still have the OEM heat shield on.
Here is what Spoon US had to say about wraping their header with Thermo Tech wrap. I feel a little at ease now, but keeping my fingers crossed.
rders@spoonsports.us]
Sent: Monday, August 09, 2004 1:47 PM
To: emmar@prtc.net
Subject: Re: Heat Wrap Header
As for the headers wrapped with Thermo Tech, we have not heard of anywone that
had a problem.
However, when you wrap the headers, you actually contain the heat for
accelerated push to the exhaust, which is good.
Keeping the headers wrapped also keep the engine compartment cooler than
usual, which is also good.
Other than that, if you feel your cars runs well with it, I'd say, its okay.
Opak
> I have one of your Spoon header on my S2000 and I wrapped it with Thermo
> Tech wrap to contain heat and keep my engine bay cooler.
> Will this affect the header in any way? If so, how?
> Thanks.
rders@spoonsports.us]Sent: Monday, August 09, 2004 1:47 PM
To: emmar@prtc.net
had a problem.
Opak
> Thanks.
What about getting the header ceramic coated? I'm looking to do this if I get an aftermarket header 'cause there aren't too many other than Mugen (and maybe one other, I don't know) that use a heat shield mounted to the header itself.
I do not really know how efficient the ceramic coating will be at retaining heat, but the point is that a thin-walled header only has so many heat cycles before the welds and/or the pipe become brittle and break. If you are going to retain more heat in your headers and drive your car daily, I would suspect that you will see problems. The problems may not occur for several years, but eventually you will crack or completely break your header.
This is of course my .02 dollars.
I've spoken with JET HOT and their coating when applied to the inside and outside should help prolong the longevity of the header. The gentleman I spoke with stated that applying JET HOT should reduce the heat given off by 30% or more. With regards to retained heat breaking a header, I'm not sure this is something to really worry about. Hotter air flows faster out of the header thus the welds shouldn't be negatively affected anymore than without the coating. Also, while I'm not 100% on this, applying a coating to the inside might also protect the welds.
Any opposing input is welcome. We can all learn from the more knowledgable members.
Originally Posted by Kaolinte,Aug 6 2004, 11:20 PM
The advantage is in weight reduction. The lower heat shield on the stock header weighs a little over a half of a pound. With that much weight being taken off, your are going to feel quicker acceleration and better throttle response.
Header wrap is a big
on thin-walled headers if you are driving the car daily.
on thin-walled headers if you are driving the car daily.What my rambling means is that I think wrapping a header should be ok.
