help!
Old Feb 26, 2012 | 10:49 AM
w35t_ap1's Avatar
Default help!
i was tightening down the ignition coil bolts after a spark plug replacement and number four sheared off into the valve cover.. what should i do to get it out?
also - it would not be a good idea to run the car with that bolt broken.. true or false?
Old Feb 26, 2012 | 12:12 PM
zeroptzero's Avatar
Try a bolt extractor kit to get the broken piece out. You could drive a limited distance without a bolt on the coil if needed, I don't think it will lift up on it's own over a short distance or short period of time but you will need to bolt it down for longer term use. Don't leave it too long.
Old Feb 26, 2012 | 04:37 PM
w35t_ap1's Avatar
extraction kit cost 2 dollars and worked like a charm... thanks!
Old Feb 26, 2012 | 05:01 PM
zeroptzero's Avatar
Good price and good work
kap
Nov 13, 2015 01:17 PM
seansniper
Dec 8, 2011 05:46 AM
seoul2k
Nov 11, 2010 07:46 AM
s2k_suprchrgd
Sep 11, 2005 12:52 AM
DJSang
Oct 16, 2002 01:46 AM
