HELP! Battery problem
Old Feb 2, 2008 | 03:19 PM
Carson07S2K's Avatar
Default HELP! Battery problem
While trying to put the battery back in the car, my g/f accidentally reversed the terminals for + & -. The horn/alarm was going crazy until she called me and I had her disconnect it. Now the car will not start and is dead.
What exactly happened? What is wrong and what should I do to diagnose the issue?
- Is the battery dead/fried?
- Is the alternator fried?
- Any fuses blown?
Thanks
Old Feb 2, 2008 | 03:49 PM
S_Sense's Avatar
First of all, Have your g/f connect the battery the right way and let her try it out while you go and try to find some dignity.
Old Feb 2, 2008 | 05:14 PM
Mrfixit687's Avatar
you most likely blew out a few fuses, look under the fuse box and see which ones are blown, i'm guessing you blew the main/alternator fuse, like big 40amp or 50amp ones.
Old Feb 2, 2008 | 07:20 PM
negcamber's Avatar
I hate to admit...but my brother did the same trying to help jump my car. The main fuse blew...no other damage...at least that I ever found.
Old Feb 3, 2008 | 02:33 AM
nakdboardr's Avatar
[QUOTE=Carson07S2K,Feb 2 2008, 07:19 PM] While trying to put the battery back in the car, my g/f accidentally reversed the terminals for + & -. The horn/alarm was going crazy until she called me and I had her disconnect it. Now the car will not start and is dead.
- Any fuses blown?
Thanks
Old Feb 3, 2008 | 06:19 PM
asukadc's Avatar
check the fuses first
Old Feb 4, 2008 | 04:16 AM
Fuses appear to be fine unless my fuse tester is lying to me.
Old Feb 4, 2008 | 09:55 AM
The S is on the way to a dealer. Just left on a flatbed
Old Feb 5, 2008 | 08:03 AM
The S is ready to go. The main fuse blew and the dealer replaced it and the battery charged right back up. Going to pick it up later.
And just to set the record straight, she was only doing this b/c of an emergency. Unfortunately, she created a bit of chaos.
The g/f is lucky but still needs a
1RM
Jun 26, 2024 08:27 PM
wanabe
Jun 7, 2014 04:33 PM
vasquezgno
13
Mar 29, 2013 12:55 PM
BionicButoBob
Jul 4, 2009 07:01 AM
LubedKoala
Aug 26, 2006 08:15 AM
