Help. CEL on INVIDIA test pipe ...
Old Feb 1, 2008 | 07:39 AM
THE_DIESEL's Avatar
Default Help. CEL on INVIDIA test pipe ...
What do I should make?
Thanks
Old Feb 1, 2008 | 07:50 AM
screaminyellow's Avatar
Thanks
Did you try an anti-fouler for the o2 sensor?
Old Feb 1, 2008 | 08:09 AM
THE_DIESEL's Avatar
What ???
Old Feb 1, 2008 | 08:10 AM
THE_DIESEL's Avatar
With cat no CEL...
Old Feb 1, 2008 | 08:16 AM
passmans2kny's Avatar
yea its the o2 sensor, look up cel fix for o2 snesor im sure u will find your anwser
Old Feb 1, 2008 | 08:17 AM
S2005x's Avatar
Do this
http://www.eclipseforums.org/ftopict-194547.html
Old Feb 1, 2008 | 09:13 AM
Tyraid2K's Avatar
I'm looking up all your post The Diesel
Old Feb 1, 2008 | 09:17 AM
S2005x's Avatar
lol why?
and that s2000 transformer is awesome. i have one too
Old Feb 1, 2008 | 05:11 PM
ScubaDivin's Avatar
Do you have the 60mm test pipe or 70mm? I know the 70mm has a "built-in" O2 fix in the pipe but my CEL still got set off a day after intallation. Just the other day when i changed my oil, i pulled my "back-up" fuse to reset my ECU and the CEL hasn't come back on in a week.
Basically, if you are setting off the CEL and you have the built in O2 fix inside your INVIDIA test pipe, you HAVE TO reset your ECU . The ECU needs to RE-LEARN the the A/F ratio with the absense of the catalytic converter. Try it!
Old Feb 1, 2008 | 05:12 PM
txs2knoah's Avatar
stack 2 anti-fouler
