Help with CEL P0411
Old Oct 14, 2003 | 04:51 PM
Stratocaster's Avatar
Default Help with CEL P0411
I replaced my CompTech CAI and went back to stock. I carefully routed all the VAC line properly. The first time I got the CEL was the next day. I have found that I had forgotten to tighted the clamp on the TB. Since then I have had it 4 times. After the second time, I removed and reinstalled all VAC lines to be sure they were connected tightly. After the CEL code is cleared it seams to last for 24/48 hours. It only happens when the car is cold. THe dealer said it would take them some time to trace down where the leak is.
Has anyone else had this problem? Got a clue? Or just a WAG? (Wild A$$ Guess)
Thanks
Old Oct 14, 2003 | 05:10 PM
3ngin33r1's Avatar
Air pump.
Old Oct 14, 2003 | 05:15 PM
Originally posted by 3ngin33r1
Air pump.
Can you explain what I can do about it?
Old Oct 14, 2003 | 05:18 PM
xviper's Avatar
Is that little white one way check valve facing the right way? If it got turned around, it would take a bit of a delay before the CEL would trip.
Old Oct 14, 2003 | 05:24 PM
3ngin33r1's Avatar
[QUOTE]Originally posted by Stratocaster
Old Oct 14, 2003 | 05:26 PM
3ngin33r1's Avatar
This one has a little more detail but I think you should be looking at the ACSV (Air Control Solenoid Valve).
Old Oct 14, 2003 | 05:36 PM
[QUOTE]Originally posted by xviper
3ngin33r1's Avatar
I'll go snap one right now. BRB...
Old Oct 14, 2003 | 05:41 PM
3ngin33r1's Avatar
Left side is going to the Air Control Valve Vacuum Tank. Right side is going to the intake manifold.
Old Oct 14, 2003 | 06:08 PM
Yep, that is how I think I have it installed. I will recheck.
Thanks Marcus
