HELP!!! Check Engine Light CODE
Old Feb 15, 2002 | 07:39 PM
turbomadness's Avatar
Default HELP!!! Check Engine Light CODE
Hi, I need some help. Does anyone know where I can find a list of check engine light codes for a 2000
s2000? I currently have one check engine light code that flashes 6 slow times (60???). Thanks for the
help.......
Old Feb 15, 2002 | 07:54 PM
Schatten's Avatar
uhmm, I'm not so sure that is a check engine code. usually you'd interface into an ODBII application or handheld unit to find out the code. correct?
you might want to try checking the FAQ section (above at the top of the screen) and reset the check engine light. if it comes back, then there is something more than just a fluke reading, if it goes away, just watch for it for the next few days.
Old Feb 15, 2002 | 10:44 PM
Pappy's Avatar
If the Check Engine light stays constantly lit, then the problem is no big deal. But when it flashes, that usually means the car is running really bad. Not good!
My cousin accidently shifted from 3rd to 2nd while racing, and a few seconds after he finished, the light came on flashing, and the car idled really rough!
Old Feb 16, 2002 | 01:07 AM
Schatten's Avatar
Pappy - and a few grand later he got a new valve train, right? Sounds like your cousin bent some valves.
Old Feb 16, 2002 | 03:38 AM
DaveA's Avatar
Sorry for the possibly dumb question but... Are you sure you're not looking at the Maintenance Required light? How many miles on the car?
Old Feb 16, 2002 | 08:59 AM
XTC at 9K's Avatar
It just so happens that I have a '01 shop manual handy...
And if you counted correctly Code 6 is...ECT- Engine Coolant Temp. Senor Cct. either high or low Input
Code 5 MAP (Manifold Absolute Press. Sensor Signal either High or Lower than expected
Code 7 TP - Throttle Position Sensor either high or low input
Old Feb 16, 2002 | 09:03 AM
XTC at 9K's Avatar
Its probably best to try and reset the system b4 any further troubleshooting! You never know it could be just a glitch.
To reset, Turn the Ign switch off and remove the No. 25 BACK UP FUSE (7.5A) from the under dash fuse box for 10 sec.
Old Feb 16, 2002 | 10:58 AM
Pappy's Avatar
Shatten,
Actually he got REALLY lucky. He only cracked to rocker arms and thats it. Not bent valvles. Ironically the dealership covered it under warranty!
Old Feb 17, 2002 | 02:06 PM
Utah S2K's Avatar
[QUOTE]Originally posted by XTC at 9K
[B]Its probably best to try and reset the system b4 any further troubleshooting!
Old Feb 17, 2002 | 02:22 PM
Utah S2K's Avatar
[B]It just so happens that I have a '01 shop manual handy...
