Help with Engine Damper Installation
Just received my engine damper(it was from ebay) but the instructions are in japanesse. I looked in the DIY to see if there was a topic on it but couldn't find anything. Does anyone know where I could get instructions to install this.
Thanks
Thanks
The damper itself,is the same for most cars;the difference is in the attachements,brackets etc...
You"ll have to remove or make a hole through the heatshield,for the damper to go through,and remove the fuse box,and fit the bracket there.
Good luck, and post pics of the completed job.
Is the stock battery heat shield easy to remove.. Haven't looked at it yet. Everything else seems pretty straight foward on how to install the engine damper viewing other installed s2k pictures with it installed
As for the damper, the install is easy enough. You might need to pick up a bolt so you can bolt the bracket to the block.
You will have to remove the metal bracket on the shock tower holding the fuse box. It gets in the way of the ETD bracket. The fuse box is safe enough on there with just the one bracket.
I had a custom mount made - welded the bracket to the foot of my spoon STB and had another mount made for the fuse box. Ill post up some pics later if someone wants them.
As for the hole in the heatshield - measure twice, cut once. Getting it all to line up correctly is not as easy as it looks.
Originally Posted by dadgumit,Aug 25 2006, 03:22 PM
does this actually have a material effect on performance? Like to hear how it goes.
None whatsoever.!!!
But it sure looks damn good;that's why,I want one.!!!!
Originally Posted by Emil St-Hilaire,Aug 25 2006, 06:54 PM
None whatsoever.!!!
