Help, engine won't start
Old Jun 4, 2014 | 01:56 PM
2001-S2k's Avatar
Default Help, engine won't start
Hi everyone, my s2000 wont start
The car itself cranks but will not start.
-I recently did the ap2 retainer upgrade
-Put new spark plugs in the car
-Adjusted the valves (because of retainers)
-Put the camshafts back on and triple checked the timing, the lines matched up.
The car hasent run for over a month, but gas is in the tank.
What could be causing this issue??
Thanks everyone
Keith
Old Jun 4, 2014 | 02:26 PM
2001-S2k's Avatar
All the wires look to be connected correctly as well
Im charging the battery as i write this, i'm hoping it is just that.
Im just not sure because it had enough power to crank the engine. The dash lights did dim quite a bit.
Im crossing my fingers I did everthing right
Old Jun 5, 2014 | 05:50 PM
2001-S2k's Avatar
Solved. Exhaust cam was 1 tooth off.
FIRSTCAR-S2K
Jan 19, 2017 11:04 AM
ofsalesmen
Mar 10, 2014 11:37 AM
simmoyo
May 20, 2012 03:27 PM
hippos2k
May 10, 2009 10:46 AM
kboardsurfer
May 22, 2007 02:50 AM
