HELP HELP! I need help removing KW V3 coilovers
Old Mar 12, 2008 | 06:37 PM
Lino8419's Avatar
Default HELP HELP! I need help removing KW V3 coilovers
Just put them in and theres a problem. i have no spring compressor. is there an easy way to get them out. i took out the lower control arm bolt and the two top ones where the coil over locks in. and its stuck. any ideas??
Old Mar 12, 2008 | 06:49 PM
2poor2mod's Avatar
take out the two bolts that hold the upper control arm to the body, should drop right out after that
Old Mar 12, 2008 | 06:54 PM
negcamber's Avatar
You can use the adjusting collar to compress the springs since they are coilovers. Will just take some time.
Old Mar 12, 2008 | 07:03 PM
Lino8419's Avatar
Does any one know if there is supposed to be a rubber bushing under the top hats?? In this install review https://www.s2ki.com/forums/index.php?showtopic=259346
it doesn't really show if it's supposed to be underneath. His step says "Assemble the KW damper like this, the large black washer from the stock shock goes on the end of the shaft." then his next step is here is the completed assembly. is there a rubber bushing under that. thanks for any help!!!!!
Old Mar 12, 2008 | 07:06 PM
RacerXI's Avatar
There is a rubber insulator under the stock top hat.
Old Mar 12, 2008 | 07:09 PM
Lino8419's Avatar
Ok so thes a rubber bushing on the top and bottom. is it going to make a big difference if i put the old ones on...even if they don't look great?
Old Mar 12, 2008 | 07:12 PM
RacerXI's Avatar
The rubber is only above the washer. It more or less cushions the top of the spring on the metal hat. It'll be ok to put the old ones back in.
Old Mar 12, 2008 | 07:16 PM
Lino8419's Avatar
how about that purple thing at the top of his coilover. i don't have those? are those important?? thanks for the help!!!!!!
Old Mar 12, 2008 | 07:35 PM
RacerXI's Avatar
The purple things are supposed to "center" the spring inside of the top hat. I won't comment on them being important or not, but there are kits that don't include that part.
Old Mar 12, 2008 | 07:44 PM
Lino8419's Avatar
alright my kit didn't come with them.....so i'm just going to go without them.
