Help with identifying engine tapping noise
Old Apr 10, 2022 | 07:55 AM
gamer77's Avatar
Default Help with identifying engine tapping noise
Hello guys,
I have this problem I've been trying to figure out for a while - when engine is warm, it's making distincitve tapping noise at idle, I think it can be clearly heard at the videos below. I checked how the bad TCT sounds like and it's a different sound to me, but I'd like to hear your opinions.
It's 2001 AP1, 170k miles on the clock, valve adjustment done 1k miles ago (they were a little bit tight before adjustment), not throwing any CELs, runs and drives good, except burning pretty serious amount of oil which I top up every time (I guess with that mileage on AP1 it's not so uncommon).
Cold start (not sure why the video is mirrored but that's irrelevant):
Idle when cold:
Idle when hot (after 30 mile drive):
Any input appreciated, thanks in advance!
Old Apr 11, 2022 | 03:32 AM
Slowcrash_101's Avatar
Sounds normal to me.
Old Apr 12, 2022 | 06:07 AM
BrewDay09's Avatar
Sounds like the valves are just adjusted on the loose end of the range. No worries.
Better to hear them than to smell them.
Old Apr 15, 2022 | 04:05 PM
JFrost95's Avatar
Warmed up it sounds exactly like mine. This car has the worlds noisiest injectors and valves so as you move your head around the engine bay the sound is always coming from somewhere else lol I found a video on youtube that was basically a clone of this post. Sounded identical.
Old May 9, 2022 | 01:36 PM
reallyangrydinosaur's Avatar
Did you ever figure out the source of the noise?
Old May 10, 2022 | 12:31 AM
robjoshua228@yahoo.com's Avatar
You should hear the engine on my recently sold Mazda MX5 (NC), luckily I had an aftermarket muffler which ironed out the noise
Old May 10, 2022 | 04:41 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
All engine noise videos need to be recorded with the hood closed. It is the only way to pinpoint individual noises.
Old May 10, 2022 | 08:12 AM
gamer77's Avatar
No, after the posts I just assumed everything is fine.
Good advice, I can make that happen and post it here by the end of the week
Old May 11, 2022 | 01:07 PM
gamer77's Avatar
Uploaded!
Old May 12, 2022 | 12:32 AM
I am no mechanic and do not claim to have any mechanical skills, I would have someone look at that for me . . .Given that expense of something going wrong, something you could have addressed, I would have it checked by someone who is very familiar with these engines. Good luck and do update us on the outcome.
spartanga
Apr 16, 2020 04:56 PM
Nitewolfgtr
Aug 14, 2014 03:53 AM
Siby
Jun 25, 2012 05:55 PM
damsas
Mar 2, 2006 05:44 PM
