help identifying noise. video!
Old Aug 15, 2012 | 10:28 AM
AlanS2000's Avatar
Default help identifying noise. video!
Hi everybody,
I am hoping you can help me out in diagnosing a rattle/grinding sound I get when I lift off the throttle.
The noise ONLY happens when I lift off the throttle and the engine is slowing the car.
Throwing it into neutral or getting back on the throttle even a tiny bit makes it go away.
In the video, you can hear it at the following times: 8, 25, 37, 40 onwards you can really hear it as I get on and off the throttle.
(sorry about the buzzing at the 15 -24 second range. that was shift knob rattling against phone) Thanks!
[media]http://youtu.be/pN-1UDHzdD0[/media]
Old Aug 15, 2012 | 10:58 AM
Nemi's Avatar
Im having the exact same sound as you and it's only happening when the engine is slowing the car
Old Aug 15, 2012 | 01:09 PM
s2000maniac's Avatar
Check the differential mounts.
What year s2k? How many miles? Any mods?
Old Aug 15, 2012 | 02:24 PM
AlanS2000's Avatar
it feels like the sound is coming from the front but i will take a look
its an 04 with around 80k. stock except for pss9 coilovers and i am guessing the previous owner put in an aftermaket clutch and possibly flywheel.
maybe this is clutchbuzz?
Old Aug 15, 2012 | 03:24 PM
Forcedbird's Avatar
I have an ACT clutch, PP and Flywheel. It does sound like clutch buzz to me but again I am trying to diagnose off of a video. Does the car make any noise at idle in neutral? And if it does, if you press the clutch in does it go away?
Is there any way you can contact the previous owner and ask if he installed an aftermarket clutch?
Old Aug 15, 2012 | 03:29 PM
AlanS2000's Avatar
no noises at neutral or idle, clutch in or out.
no way of contacting previous owner, but he did give me a stack of papers and receipts that i can browse through.
Old Aug 16, 2012 | 04:24 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That is clutch buzz 100%, especially if you used any other disc than oem. Guaranteed.
in the future ACT PP + oem disc.
Old Aug 16, 2012 | 07:20 AM
Nemi's Avatar
If i buy OEM Disc, pp and bearing will that get rid of the sound?
Old Aug 16, 2012 | 09:49 AM
AlanS2000's Avatar
Thanks Billman.
http://www.hondaautomotiveparts.com/...H&vinsrch=null
in this diagram the friction disc (#2) is what is making that noise?
I think i might go with a full OEM AP2 setup (maybe AP1 flywheel) unless you think that the wrong move?
kukudm
Sep 23, 2022 12:50 PM
Tveliskos
Aug 29, 2016 06:22 AM
jeffers
Feb 17, 2012 09:57 AM
leekor12
Mar 8, 2010 01:05 PM
Corleone
Aug 19, 2003 08:22 AM
