Help! Metal bits came out during diff flush:(
Old Sep 2, 2013 | 11:06 AM
F22C1-215's Avatar
Default Help! Metal bits came out during diff flush:(
NOw my04 diff has been having sOme clunky noises for some time now. Mostly in neutral at low speed turns. Today i drained the diff to change the fluids out and had a bunch of metal which really concerns me. My question is should i buy a whole diff unit, or buy gears and bearings/seals? I am capable of repairing it with new gears /etc. Which one would be the cheapest option/ best option? I do plan on S/C next year. Keeping that in mind. Any help would be greatly appriciated.
Old Sep 3, 2013 | 09:48 AM
CoolGuy094's Avatar
You need to elaborate on "bunch of metal". What size were the pieces of metal? Like grains of sand? Or a finer paste? Or bigger chunks?
Old Sep 3, 2013 | 08:25 PM
BlakeNFR's Avatar
Small sand/paste= Okay.
Metal pieces (bigger than lets say crumbled frosted flakes), you're probably gonna need a new diff. If you don't launch your car a lot, you shouldn't be too worried.
Old Sep 4, 2013 | 03:13 AM
speakeasy2009's Avatar
Here is what my diff drain bolt looked like when mine went bad....if yours looks anything like this your diff is bad...
Old Sep 4, 2013 | 06:11 AM
CoolGuy094's Avatar
Old Sep 4, 2013 | 08:16 AM
iamxpl's Avatar
wow that is wild. its heart breaking just thinking about the atrocity that went on in that diff when that happened.
Old Sep 4, 2013 | 08:49 AM
INDYMAC's Avatar
What gear oil are you using? Any pictures of metal that was drained or drain plug?
Old Sep 4, 2013 | 08:51 AM
s2kreeper's Avatar
New diff is definitely in order.
Old Sep 4, 2013 | 12:39 PM
RIDGERCR's Avatar
I work on aircraft for a living and seeing those chunks on a mag plug is a big show-stopper itself. Take what the guys here say and start looking for a replacement diff. Just my 2 cents. At least it's not in the tranny. Good luck with it.
Old Sep 4, 2013 | 12:53 PM
steamedturtle's Avatar
Small metal shavings are normal to find during diff fluid changes, big chunks like those pictured are bad.
