Help - Mil On!!!
Old Jul 12, 2002 | 04:43 PM
matrix's Avatar
Default Help - Mil On!!!
Hoping someone can help me here...
The MIL is on and I cannot find or feel a problem with the car. I checked the gas cap and made sure it was tight, but not past 3 clicks...no help. Manual says it takes 3 driving trips for it to clear. What is a driving trip? I took it as turning the car on/off 3x, so I drove, turned it off, started, drove, off, etc...MIL stayed on.
Any suggestions?????
Thanks
Old Jul 12, 2002 | 05:17 PM
jerrypeterson's Avatar
You mean the CEL right? What is a MIL?
Old Jul 12, 2002 | 05:21 PM
matrix's Avatar
MIL = Malfunction Indicator Lamp...that is how it is listed in the manual. But it is the CEL.
Old Jul 12, 2002 | 05:32 PM
Chazmo's Avatar
Matrix,
:cracks seal on $80 service manual:
Er.... I don't know if you should just aim to turn this thing off, Matrix. Just a few steps in to the MIL circuit troubleshooting section it starts talking about connecting to OBD and doing some diagnostics...
OK, reading on for you... Will post again soon. Now I'm curious.
Old Jul 12, 2002 | 05:38 PM
Chazmo's Avatar
Just checking here, are you sure you mean the MIL, or could you mean the maintenance required indicator, Matrix? The maintenance lamp is two positions to the left of the MIL.
Old Jul 12, 2002 | 05:42 PM
matrix's Avatar
It's the one with the engine and with the word check in it...not sure why the owners manual calls it the Malfunction Indicator Lamp. I usually call it the Check Engine Light, but thought I should get the right term...
Old Jul 12, 2002 | 05:50 PM
Chazmo's Avatar
You're right. That's the MIL, matrix.
I think the reason they don't call this a check engine light anymore is because it applies to the entire car.
I'm reading the manual, and the MIL is telling you that some subsystem in the car has detected a problem.
The trick (I can't quite figure this out) will be to coax the computer to spit out the "DTC" (failure codes, documented in the shop manual).. My '88 prelude had a way to make the computer flash an LED with the code, but I don't know if there's anything like that in the S. Arrrrrrgh!
Still looking, matrix!
Old Jul 12, 2002 | 05:53 PM
matrix's Avatar
Yes, the owners manual says it could be something in the emission system or the gas cap...well I checked the gas cap...
Old Jul 12, 2002 | 05:56 PM
Chazmo's Avatar
I think this thing is triggered by many more things than that, matrix. DTCs can come from ABS, heating/ventilation, SRS (airbag), fuel/emissions, and of course engine management.
I'm just reading this first time, tho, matrix... Do you have the shop (service) manual (textbook-sized blue book)?
Old Jul 12, 2002 | 06:03 PM
matrix's Avatar
No, I don't Chazmo...thanks for taking the time to read this for me .
