Help with my S2000!
Old Dec 4, 2004 | 02:54 PM
_s2kJimmy's Avatar
Default Help with my S2000!
Ok my car has been pretty shabby for the past couple of days. First the maintenance light appears and I think nothing of it since I just changed all my fluids and filters. Then when I turned my car on a couple of days ago when it was cold it reved up and down and idled below 1k. I blew that off as well, but now when i start it up it dies. When I drive it, it dies. When I start it up and proceed to step on the gas it makes a putt putt noise and the rpms don't move. I've taken it to two shops, a mechanical shop and John Eagle Honda. They gave me the following codes...
0300, 301, 302, 303, 304 misfire on all cylinders, p1399 air/fuel mixture problem.
Both said that it could be anything and they don't know the exact problem. They said it might be the IAC, one of my sensors, etc. Anyone have any idea what is going on?
Old Dec 4, 2004 | 06:20 PM
bassoclone's Avatar
Did you or they check the plugs? Have you had them check the timing? Also, it might be time to find a new dealership if they actually told you "they don't know..." that would make me uneasy about returning my car there for work.
Old Dec 5, 2004 | 01:57 AM
9kFever's Avatar
maintence light has nothing to do with it. I take it you got a cel
Old Dec 5, 2004 | 06:46 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
This actually sounds simple enough to fix. Any decent tech should be able to read your STFT/LTFT numbers, do some flight recording and fix the dam thing. Wish you were closer...
Old Dec 5, 2004 | 09:29 AM
vitec's Avatar
did you overrev it ,sounds like bent valves
Old Dec 5, 2004 | 02:21 PM
Billman250's Avatar
Top Answer: 1
This is all too true...If the "Maint req'd" light started flashing, it is total coincidence. The CEL however (little picture of an engine) is directly related. I think you A/F code is causing the misfire codes, so I'd start with viewing your STFT (short term fuel trim) It is likely pegged, and may be at max +FUEL correction.
Nfrs2kiguy
Dec 28, 2014 03:41 PM
Shaney
Oct 3, 2014 02:47 PM
myslows2k
Mar 11, 2009 07:41 PM
2000s2000mike
Jul 4, 2006 06:38 AM
efthimios
May 1, 2003 02:02 PM
