Help!!! o2 simulator installed....now the car bogs or stalls!
Old Jun 27, 2004 | 12:56 PM
phaze826's Avatar
Default Help!!! o2 simulator installed....now the car bogs or stalls!
well i installed the egc o2 simulator just as S2KEvolution
diagram showed....and now my engine will stall or go all the way down to less than 500rpms after i rev the engine......what can be the problem here....the way i spliced was with special splice conectors...is this at fault?...what can be the problem plz leave your input thanks
Old Jun 27, 2004 | 01:27 PM
Ludedude's Avatar
Administrator
Yes, remove O2 simulator, return emissions system to properly operating parameters.
Old Jun 27, 2004 | 01:53 PM
phaze826's Avatar
problem fixed!!!...it was my splice conectors....they weren't woprking properly...i spliced every wire and did it properly!!!...alot of thnx to S2KEvolution for very good write up and diagram NOW IT WORKS PERFECTLY!!!
Old Jun 27, 2004 | 03:01 PM
Spankee's Avatar
Splices aren't very good, you should soilder the connections to ensure troublefree performance. Splices tend to work loose and have bad connections after time.
Old Jul 31, 2004 | 06:36 AM
agc_23's Avatar
Do I need to keep my O2 Sensor installed on my car after the simulator is Installed? Because my O2 Sensor is waisted and I install the ECg O2 sim and I still have the CEL. Can I turn the cel of without the O2 Sensor?
Old Jul 31, 2004 | 07:21 AM
Slows2k's Avatar
The 02 sensor needs to be installed to keep the CEL out for a faulty 02 heater. You can either leave the 02 connected, or wire a 13ohm 10 Watt resistor in the 02 heater circuit.
DRKNT
Mar 30, 2012 11:06 AM
cmc600rr
Oct 5, 2011 06:35 AM
tkeyyy
24
May 10, 2011 07:15 AM
JLuda
Jun 13, 2007 07:28 PM
