help please clutch fluid
Old Feb 16, 2006 | 07:13 PM
pzach's Avatar
Default help please clutch fluid
Hey i need some help I'm getting ready to flush and re-bleed my clutch I first need to know what fluid to use and how much. I know most will recommend dot 3 or 4 if so what kind and where to buy? Any help will be greatly appreciated as I need to get this done a.s.a.p.
Old Feb 16, 2006 | 07:31 PM
HondaS2kRay's Avatar
Go to Honda and buy a bottle of their brake fluid. Do NOT buy any other brake fluid besides that. I'm not saying it to limit your choices but IMO using honda fluids especially brake/clutch fluid is important. They have added protection other brake fluids lack.
Go to walmart and get:
1) Suction syringe or bulb out of the baby section
2) Windshield washer rubber tubing out of automotive
3) protective latex gloves
**You will also need an 8mm or 10mm (I forget which size) box end wrench to loosen the bleeder valve.
-Make sure you cover your fender with towels or anything to keep accidental fluid spills OFF your paint. It will seriously have some adverse affects if you get clutch fluid on your car.
-Suck all the old dirty fluid out with the syringe/suction bulb and get it as clear as possible.
-Next, jack the car up and put a jackstand underneath it and have a friend sit in the drivers seat ready to pump the pedal
-Fit the box-end wrench over the bleeder valve and install the rubber tubing on the nipple... (hehe)
-Loosen the bleeder valve and tell he/she to press the pedal down. Immediatly after they press it close the valve so no air gets in. Your friend will have to bring the clutch pedal back up because the pedal will stay down. Repeat this until you see clear fluid go into the bottle your using to capture the fluid. After the last pump close the valve immediatly DO NOT TIGHTEN IT TOO TIGHT, it doesn't require a lot of torque. Make sure you watch the resevoir between pumps to see if its getting low and refill if necc.
Hope this helps out!!!
Old Feb 16, 2006 | 08:03 PM
pzach's Avatar
Hey thanks for your detailed reply I'm using motul 5.1 for my brakes would that be ok for my clutch?
Old Feb 16, 2006 | 08:05 PM
SenderGreen's Avatar
The bleeder valve on the slave cylinder is 8mm. Xviper has a step by step DIY in the FAQs section. Good Luck
https://www.s2ki.com/forums/index.php?showtopic=118878
Old Feb 17, 2006 | 10:17 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Use Valvoline DOT 3 for street driving.
Old Feb 17, 2006 | 05:24 PM
Ludedude's Avatar
Administrator
[QUOTE=HondaS2kRay,Feb 16 2006, 08:31 PM] I'm not saying it to limit your choices but IMO using honda fluids especially brake/clutch fluid is important.
Old Feb 17, 2006 | 05:56 PM
The back of my owners manual (MY 03) it says to only use DOT 4 as a temporary replacement for DOT 3. I have been told that DOT 3 has a higher boiling point than DOT 4.
Ignore that, I think it only applies to the brakes. Sorry I zoned.
Old Feb 17, 2006 | 07:26 PM
Ludedude's Avatar
Administrator
DOT 4 has a higher boiling point than DOT 3 does.
Boiling point is irrelevant in the clutch system.
Old Feb 17, 2006 | 08:12 PM
pzach's Avatar
Alright guys so what specific fluid do you recommend for my clutch?
Old Feb 18, 2006 | 01:44 AM
RACER's Avatar
Whatever your using in the brake master cylinder you can use for the clutch as well whether it be dot 3, dot 4, Honda fluid, valvoline, castrol, Kmart, Safeway brand ect.
