Help, quick quesiton
Old Jul 27, 2006 | 01:14 PM
P'sS2k's Avatar
Default Help, quick quesiton
for those of you who hook up the air fuel ratio, where did u tap the 02 sensor at? thanks
Old Jul 27, 2006 | 02:14 PM
Ek9's Avatar
Ek9
Banned
The O2 sensors on the 00-03 S2K won't tell you AF ratio. They're the old fashioned narrow band sensors that just tell you "rich" or "lean". If you want to know the mixture, most people install a wideband O2 sensor which swings from about 1-5V's and it directly readable for mixture.
Old Jul 27, 2006 | 03:21 PM
xviper's Avatar
If you are hooking up a narrow band gauge into the stock O2 sensor, you need to "T" tap in to the WHITE wire at pin #16 on the 31 pin connector that goes into the underside of the ECU.
Here is my old narrow band gauge, more commonly known as "Christmas lights". This kind only gives you a rough range of a/f.
If you want an accurate display of a/f, you'll need the wide band that comes with its own O2 sensor that must be installed in your header. Here's mine:
Old Jul 28, 2006 | 10:37 AM
r_duff's Avatar
oooooh i want a wideband
i have an autometer narrowband and its all but useless.
Old Jul 28, 2006 | 11:15 AM
K-Lo's Avatar
Originally Posted by xviper,Jul 27 2006, 03:21 PM
now that's bit chin
Old Jul 28, 2006 | 11:51 AM
xviper's Avatar
If anyone's interested, here's the complete install on the UEGO wide band:
https://www.s2ki.com/forums/index.ph...&f=71&t=267255
03spa
Aug 2, 2010 03:31 PM
vadhert
Apr 26, 2009 09:13 AM
LHP_Sailor1P
Jul 30, 2006 03:36 PM
payyourtoll
Jun 20, 2003 04:44 AM
S2K
Sep 13, 2002 12:21 PM
