HELP removing tranny
Old Sep 28, 2005 | 01:46 PM
00s2k9k's Avatar
Default HELP removing tranny
i Got a 00 s2k and im doin a motor swap...and the tranny WONT come off for some reason...i took all the bolts around the trans and it wont pull off all the way off...ne ideas?????????
Old Sep 28, 2005 | 02:02 PM
Wisconsin S2k's Avatar
get a helm's manual.
Old Sep 28, 2005 | 02:20 PM
00s2k9k's Avatar
ok..neone else?
Ludedude's Avatar
Administrator
You're sure you got the bolt up top that also connects to the starter?
Woodson's Avatar
and try typing a proper subject line
Old Sep 28, 2005 | 02:32 PM
00s2k9k's Avatar
yea i got that
Old Sep 28, 2005 | 02:46 PM
Ludedude's Avatar
Administrator
Then you probably got the wrong one
Been there, done that. When all the bolts are out, the tranny slide out like butter.
Old Sep 28, 2005 | 02:49 PM
xviper's Avatar
Yeah, like "HELP?" What's that? Don't we have at least 50 thousand threads that start with that?
Old Sep 28, 2005 | 03:49 PM
title fixed
Old Sep 28, 2005 | 04:25 PM
chris_barry's Avatar
The clutch fork slides into a slot in the bearing carrier and holds the gearbox in place. Unbolt the slave cylinder from the gearbox and pull the clutch fork outwards an inch. Make sure you are holding the gearbox as it will drop off.
Dont forget to put the fork roughly in place before reinstalling the box.
Good luck
