Help- Squeaking sound from rear passenger Side
Old Apr 27, 2006 | 07:31 PM
SilverStoneS2k209's Avatar
Default Help- Squeaking sound from rear passenger Side
I've been having the problem for about 3 weeks now. Its getting annoying. I thought it was the brakes but i replaced them yesterday. but noise is still there.
I looked at my spring/shocks and it looks fine. A bit dirty but i cleaned it today when i washed my car.
More info about the noise. When i drive it makes a squeaking sound from the rear passenger side. when i cruise around 1-45mph. most time while slowing down to a stop.
it makes the sound in neutral.
What else can it be?
any info would help.
Henry
Old Apr 28, 2006 | 12:42 AM
hypewilliams's Avatar
My 02 just started making the exact same noise you're talking about under the same circumstances. Anyone have any ideas?
Old Apr 28, 2006 | 01:10 AM
dbzerk's Avatar
Have you tighten the axel hub nut to 220 foot punds?
Old Apr 28, 2006 | 05:29 AM
vtec9's Avatar
it makes the sound in neutral??
Old Apr 28, 2006 | 08:40 AM
mattb1's Avatar
mine makes the sound too, most notably when in neutral rolling over speed bumps really slow. er-eeee, er-eeee
Old Apr 28, 2006 | 08:47 AM
superjimbo's Avatar
Sounds like it's a suspension issue. I would take your car to the dealership and have them lube the rear passenger control arm. You may as well have them check the axel hub nut like dbzerk said too. Finally, double check that your spare tire is tightened down in the back. Good luck.
If you do a search on this issue it has been discussed a couple of times before. You might be able to find some potential fixes if my suggestions don't work.
Old Apr 28, 2006 | 09:20 AM
Yea It makes the sound mostly in neutral. Ill try lubing up the rear end. but when i bought the car, i since havent messed with the axle bolt. But ill get that checked out also.
Thanks for the info guys.
Henry
warrenk05
Oct 13, 2020 02:31 PM
rbtz
May 17, 2018 10:09 AM
mattfeet
Sep 17, 2009 01:00 PM
Ooalloems2koO
Apr 25, 2005 01:56 PM
Chitah831
Oct 5, 2004 08:57 PM
