HELP! System Running Too Lean and Fuel Trim Code.
Old Apr 12, 2024 | 06:44 PM
Rossphosphorous's Avatar
I am curious as well but it looks like we are unlucky. I have a P0171 that appears randomly and then goes away eventually. It makes OBD read for smog in California difficult.
I have replaced oxygen sensors, spark plugs, and performed the troubleshooting procedure in there repair manual with no success in finding a problem. This includes checking EVAP, fuel pressure, and valve clearances.
Old Jun 14, 2024 | 09:19 AM
Mnbuhat's Avatar
Sorry to revie al old thread, but ive been battling this same issue with P0170 and P0171 for the past few months and hasnt gone away.
Just wanting to see if there was a fix to this thread.
Ive replaced what OP has already mentioned. Im bummed out now
Old Jun 14, 2024 | 01:55 PM
Unfortunately I have not found a solution yet. I did everything the Honda manual tells me to check and everything was as it should be. I'll update here if I ever find out the solution. I just hope the check engine light stays away whenever I need a smog check.
Old Jun 14, 2024 | 03:41 PM
Mnbuhat's Avatar
Yea, I’ll update here as well.
so far I’ve replaced:
-fuel injectors with OEM
-fuel pressure regulator with OEM
-low mileage OEM fuel pump and sock/strainer
-valve adjustment
-spark plugs with ngk
- denso upstream and downstream Oxygen sensors.
-MAP has the zip tie on it
code still comes up.
Old Jun 15, 2024 | 04:33 AM
Slowcrash_101's Avatar
Originally Posted by Mahl
I really appreciate your assistance Deckoz as I've been literally stressing out so much trying to troubleshoot this before smog test :`( Knowing this is more towards fuel related, I too was suspecting the mentioned possibilities you've stated above.
- New injectors are "OEM" injectors as the stock injectors are from Kei-hin..or at least I hope they're OEM..
- New map sensor and tie wrap was bought from Honda directly
- New Primary o2 sensor is Denso 234-4124. Purchased this as it says it will fit the s2k. Possibly wrong o2?
- Stock FPR seems like its losing pressure when vacuum attached. When I unplug vac line from manifold, idle increases. Possible collapsed vac line or bad FPR?
When you plug the FPR vacuum line your car will increase fuel pressure, so it means your regulator is working.
Old Jun 15, 2024 | 04:54 AM
-valve adjustment
This all sounds familiar to me. Let me know if you figure anything out and I will do the same. My next thing is to perform a smoke test to see if there is any minute leak that I do not know about when the engine is really warm. Maybe the code only comes on after a lot of traffic driving? Or I am just grasping at straws to try to explain something that I cannot figure out.
Old Jun 15, 2024 | 05:07 AM
Mnbuhat's Avatar
Saw that my LTFT AND STFT were all high, which I believe indicates it’s gotta be a leak of some sort somewhere.
I’ll get it smoke tested as well.
it’s been frustrating.
but I’ll also double check my work with the injectors. I don’t see any leaking from them, but I’ll try switch them out with the old and see if they’re bad. They were OEM new but I did notice the car perform worse after I changed the injectors.
Old Jun 15, 2024 | 04:23 PM
Fuel pump relay is good?
Old Jun 15, 2024 | 04:39 PM
The car runs fine and has no drivability issues. The check engine code simply comes and goes. If it were a relay issue, I imagine the problem would be more pronounced such as the car not running. But I am not a real mechanic, just a shade tree mechanic.
Old Jun 17, 2024 | 05:47 PM
bad_driver's Avatar
Got any data streams?
I'm just as shadetree as you, but I'll try to get a datastream from my car this weekend...
Kinda curious what the values are for
A/F sensor (1)
MAP sensor
A/F sensor heater
Short and Long term fuel trims
(also add some gas and see if long term fuel trims drop)
Ideally, if you have a graphing software, that'd be even better.
Also, could you take a look at the PCV system if that's sealing correctly? Maybe you've already replaced the valve, but these kinda go bad on AP1s.
