Help! Water dripping on the passenger's foot.
Old Aug 25, 2001 | 06:53 PM
Big Al's Avatar
Default Help! Water dripping on the passenger's foot.
The AC is dripping water in the cockpit on the passenger's side. I hear that there is a TSB on this problem issued by Honda. Has anyone seen it and know what it recommends?
In my case, the condensate is draining out through the drain tube but it is still dripping inside.
Old Aug 25, 2001 | 08:14 PM
Barry in Wyoming's Avatar
Looks to me like it is TSB #83 and it describes your problem.
See if you can link here:
http://www.nhtsa.dot.gov/cars/problems/tsb/
I found it through this previous thread that you also contributed to.
https://www.s2ki.com/forums/showthread.php?...tioner+dripping
Old Aug 26, 2001 | 06:24 AM
Big Al's Avatar
Thanks Barry,
From previous threads, I have looked at this link but it shows a summary only. It describes the problem but doesn't describe the fix.
I have seen copies of TSB's from Honda and would very much like to see this one hoping that it details the solution.
Old Aug 26, 2001 | 08:12 AM
dlq04's Avatar
The TSB about the A/C was published prior to my purchase at the end of Jan, as the Honda service manager made sure I was aware of it -- should I encounter it. Why not just let the dealer fix it? Are they that bad in FL?
Old Aug 26, 2001 | 08:42 AM
Big Al's Avatar
[QUOTE]Originally posted by dlq04
[B]The TSB about the A/C was published prior to my purchase at the end of Jan, as the Honda service manager made sure I was aware of it -- should I encounter it.
Old Aug 26, 2001 | 09:56 AM
cdelena's Avatar
Originally posted by Big Al
If I could get a copy of the TSB, I may be able to fix it myself and avoid the BS at the dealer.
Not all TSB's describe a fix.. many simply describe a symptom, cause, and circumvention. This one may just tell you not to run the fan on high.
reedntrack
Jul 12, 2016 01:46 PM
mmtr
Nov 25, 2009 12:33 AM
#172CR
Mar 1, 2009 05:23 PM
tudernos
Dec 3, 2007 10:48 AM
QT_S2K
May 20, 2002 03:55 PM
