hid flickers on then turns off
Old May 7, 2007 | 03:28 PM
custom_bimmer's Avatar
Default hid flickers on then turns off
anyone know why my passanger side hid flickers on for a fraction of a second then turns off?
thank you.
Old May 7, 2007 | 03:44 PM
SheDrivesIt's Avatar
Swap the bulbs from side to side to see if it follows the bulb. May be a bad ballast or a bad connection.
Old May 7, 2007 | 03:47 PM
CKit's Avatar
If an 01, it could be the death rattle of your bulb on its way to burning out.
Old May 7, 2007 | 03:54 PM
it is an 01. what do you mean by death rattle?
Old May 7, 2007 | 03:57 PM
He means your bulb may be going bad.
Old May 7, 2007 | 04:53 PM
s2klove04's Avatar
if its not any of that posted then you simply need to wire up a relay to the ballast and walah presto. your power shortage is gone.
Old May 7, 2007 | 05:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You fr$%$^ bi$%h. I just posted a fix, and the site glitched on me and lost it.
Stay tuned tomorrow and I'll tell you how to fix it.
Old May 7, 2007 | 05:01 PM
Billman250's Avatar
Top Answer: 1
It's moisture in the ballast.
Old May 7, 2007 | 08:46 PM
i am staying tuned. i would love to know how to get the moisture out of the ballast. i will check back tomorow. thanks AGAIN billman you ARE the man.
-keegan
Old May 8, 2007 | 01:47 PM
Billman250's Avatar
Top Answer: 1
round 2....
Take the cover off the ballast. There's water bridging the printed circuit board. Dry it with compressed air, and reseal the cover with a 1/16 '' bead of silicone.
Now...you'll see a big braided line with a clamp going into the ballast. Use pliers and slide the clamp back, and pull back the braided cover. You'll see a red wire and a black wire going into the ballast. Seal this with silicone as well, because this is where the water channels in.
Put the braided cover back on and the clamp
