HID replacement bulb
Old Nov 20, 2008 | 12:44 PM
ltspankme11's Avatar
Default HID replacement bulb
So my passenger HID bulb finally went out after 154000 miles. After searching everywhere, I can't seem to find clear instructions on how to replace the bulb. I removed the wheel and the plastic around the fender well, this gave a decent view of the HID ballast. Do I need to remove the back of the ballast (where it says not to open becasue 25000 volts can kill)? If so, where do I get this strange screwdriver to remove the bolt? There's got to be a better way.
Old Nov 20, 2008 | 12:50 PM
devilchrist's Avatar
no there should be a cover for the bulb.. i dont' believe you need to open the ballasts..
Old Nov 20, 2008 | 12:54 PM
But isn't the cover for the bulb behind the ballast? So should I need to remove the whole ballast itself rather than opening it?
Old Nov 20, 2008 | 01:26 PM
CosmosMpower's Avatar
Whatever you do, disconnect the battery before you go messing with any HID system.
krikke_s2000's Avatar
you have to open the headlight on the backside
you loosen one screw and then turn the plastic cover to loosen
then you will see the conector on the back off the bulb turn to loosen
then replace bulb the ballast is on the underside off the headlight
grtz kristof
Old Nov 20, 2008 | 05:29 PM
S2Sloww's Avatar
Scroll down to post Member STOPMENOT2002 <--AKA S2slow
https://www.s2ki.com/forums/index.php?showt...&#entry10955288
JspecVtec
Jun 14, 2006 11:58 PM
Blk Blurr
Apr 11, 2006 12:32 PM
e12ic
Aug 23, 2004 08:14 PM
Curt Nelson
Apr 19, 2004 02:01 PM
sebrings2k
Apr 15, 2003 10:37 AM
