High RPM stumble
Old Oct 19, 2024 | 08:29 AM
Dibsen's Avatar
Default High RPM stumble
Just put my stock exhaust back on and now my car is stumbling at high rpm in vtec.
I had an HKS single with a test pipe on for track. Only other mod is K&N fipk.
doesn’t seem like a mis fire, I’m not getting any codes. It’s not as hard as fuel cut either.
car is an ‘01 w/130k
i read somewhere about cleaning MAS but my car has a MAP sensor and it doesn’t look dirty.
Old Oct 19, 2024 | 02:06 PM
flanders's Avatar
Did you put back stock cat as well?
It's not uncommon for it to fail and block exhaust flow.
Old Oct 20, 2024 | 04:08 AM
Dibsen's Avatar
yes, cat went back on.
could the computer be recalculating the fuel map?
ran a little better last night
if it keeps up I’ll try putting the test pipe back on to see what happens.
Old Oct 21, 2024 | 09:07 AM
B serious's Avatar
Is the cat broken or clogged?
Does the engine have enough oil in it?
No, this is not a computer calibration issue. The car shouldn't stumble when switching exhausts.
Old Oct 23, 2024 | 12:02 AM
RolanTHUNDER's Avatar
Did you tighten the exhaust flange bolts properly?
Old Oct 24, 2024 | 09:48 AM
starchland's Avatar
Check oil pressure? Check solenoid screen? Oil consumption?
Old Oct 25, 2024 | 03:54 AM
Dibsen's Avatar
Thanks for all the feedback checked everything flange bolts are tight. Oil is good, problem seems to have resolved itself.
bgoetz
Sep 8, 2015 10:19 PM
marcrx5
Jun 9, 2014 05:52 PM
zach22
Nov 8, 2011 04:10 AM
Nick Graves
Aug 1, 2007 04:38 AM
