High Warm Idle
Old Mar 8, 2010 | 08:36 AM
adz9's Avatar
Default High Warm Idle
Hey Guys,
My S2000, ever since Ive had it, idles at 1600 RPM when warm. I've done some searching on here and discovered many threads saying I should clean my idle control valve.
I've just been out and done this and still the problem persists. Ive reset the ECU and pulled the backup fuse also. The throttle cable is loose and not sticking at all and the only thing I can do to stop the high idle is to pull the MAP sensor. When I do this, the idle settle to 1000 RPM, but the engine check light is on.
I cant see any air leaks in the system. What could this be? Im guessing either a faulty MAP or ICV sensor?
Ad
Old Mar 8, 2010 | 09:39 AM
JP Money's Avatar
Try a brand new map sensor. Sounds like that is the culprit. Good luck!
Day_One
Dec 28, 2016 01:20 AM
CTML
Oct 19, 2014 05:14 AM
RevRanger
Jul 19, 2014 04:22 PM
simonix
Jun 15, 2011 09:01 AM
tlogic
Nov 6, 2009 11:03 AM
